I have used ONR mixed with distilled water it works very well for me.
I used Sprayaway for the first time last night when a bird decided to bomb the window of our car. Cleaned up the bird bomb very nicely! Is sprayaway detrimental to glass sealants or coatings?Lately I have been using SprayAway and TRC Korean Waffle Weave Towels - seems to work out well.
TRC does also have a "Smitten" Glass mitt with Waffle Weave on one side / Twist Loop on the other
Link to Retail Site Removed
I am interested in any feedback on Carpro`s Calfify - as to if it`s worth the added cost - Spray Away can be had rather inexpensively....
As far as method, the key is not using too much product--If the glass is filthy I wash it first with ONR, then use a little glass cleaner to finish off. Use two cloths, one to apply the cleaner and lift anything off the glass, the second dry one to remove any trace of remaining cleaner. As far as glass cleaning cloths, when my white undershirts wear out I cut the top halfs off (under the arms) and the bottom halves become my glass cleaning cloths. Those work better for me than any of the several kinds of glass cleaning cloths I`ve gotten from detailing suppliers.
Heh heh, you guys who can clean glass satisfactorily with RW just kill me, my efforts always resulted in a total FAIL (and yeah, mixed with distilled water).
Bill D- See how time flies for us older guys?How many times have I asked you what the proper dilution is?!? (yeah, need to ask again but this time I`ll write it down)
I’m pretty sure the sample I gave you is RTU. I just abstracted it from my existing mixed up bottle and gave it to you.
Be a little careful I would say the worse it could do is streak.
It’s funny how everyone has different experiences with stuff. I tried ONR, but had a strange experience where while the glass was still wet, you could see what I can only describe as “un-cleanable spots” when the (Interior) glass was still wet -- you could scrub all you wanted, and the spots wouldn’t go away. I was afraid these areas would show up as fog/cloudiness in cold weather months.
Switched to a standard glass cleaner, and it cut through those spots. Haven’t gone back to ONR for glass since.
Sacrilege since it’s not what they say to do, but does anyone use the Zap cloths with actual glass cleaner? Seems like it could be the best of all worlds?
I’m almost certain I gave you RTU but if not, the dilution ratio is 10:1
Megs gallon of concentrated glass cleaner you can also use it as your prep wipe it’s mostly alcohol
