Just an update/bump: in Canada, at a store called Dollarama, they have the pump sprayers like the ones sold at Family Dollar - same pump mechanism, but a "pop bottle" clear plastic holding bottle. 1 liter/2.3 pints. $2.00. Certainly not industrial quality, but since they're sold as plant misters, I guess they'll do the job.
Since we are updating.
The one Family Dollar pump up pressurized sprayer I purchased last May is still going strong. It appeared to be identical to the previous two that leaked except for the price increasing to $3. So far, no leaks or problems. Same Spray & Wipe use as before.
Since I buy a lot of my chemicals in gallon containers I needed small bottles I bought them at a place called Sally's it is a womens hair place but they sell all kinds of plastic bottles.
Not cheap but they are good quality bottles.
I bought my chemical sprayers from Car Brite again not cheap but very nice sprayers.
These sprayers will spoil you they are sooo much better than what you get when you buy a QD with a sprayer head on it.
I have purchased some dispensing bottles from a beauty supply store locally, but not any spray type bottles.
I have also purchased several dispensing and measuring type bottles from U.S. Plastics. They have bottles very similar to the Micro-Restore bottles and I use those for a lot of my concentrated products such as Meg's APC, Meg's glass cleaner, DP RW&G, ONR. Never tried any of their sprayers.
Charles, the main issue that comes with a cheap pressurized sprayer is the thin wall. The parts most susceptible to wear and blowout are the bottom feet that rub against the floor. It wears quicker if the floor is broom finished concrete.
Chapin is having an online sale.
The pump up sprayers I had leak were a heavy plastic. Probably close to 1/8" thick.
The leaks were in the molding seam where the two halves of the bottle are put together during the manufacturing process.
FWIW, I also have some of the AG pump up sprayers that are also working great. They did cost quite a bit more that $3 though.
As far as trigger spray bottles, I have paid anywhere from 88 cents to 6 or 7 dollars for them and haven't had any problems with any of them.
My one trigger spray bottle disappointment was some ZEP spray bottles I got at Home Depot for about $4 or $5 each. They worked OK, but the trigger was not at all convenient for me to use. I ended up giving the sprayers away and using the bottles with my el-cheapo sprayers.
As far as the Family Dollar pump up sprayer is concerned, based on my experience with the last one, I wouldn't be afraid to try another one,
but I don't think I would buy a 1/2 dozen till I was sure the one was going to work.
Maybe they had a problem and corrected it in the later version.
