exterior plastics and trim
Envious Eric
so here is the deal....for cars like xterras, jeeps, etc with a lot of plastic black trim, I need a more durable product if one exists. Right now my process is the following:
wash, deep clean, hit with either 303 or megs hyper (temp looks).
is there something out there that will last a lot longer than 303 and add some color?????
If the trim is in good shape give Opt-Seal a try. I just tried it this weekend on the black cladding of my truck and was quite surprised. I've been using 303 but I'm hoping this lasts considerably longer.
I liked the gloss and look of Opti-Seal so I applied it to everything but the tires and tonneau cover. Even for those that prefer a different LSP; I still would recommend this for door jams, rims, wiper blades and any other area that's a pain to use a conventional wax\sealant.
Hmmm...it's that "add some color" bit that makes me think that you're after something other than an LSP-based approach.
There was another thread discussing some stuff called "C4" but oninions seem to vary as to how long it lasts.
FWIW, when I have to use a dressing type approach, I use AutoGlym Bumper Care, but I dunno if it lasts long enough to be right for you :nixweiss
....being a user of 303 on some exterior components, there are a few dressing/protectants I can certainly think of that last longer (definitely not one of 303's strong points IMO/IME). Meguiars Ultimate Protectant is one of the better ones (again, IMO/IME) in that respect but I have found it to be a little difficult to apply to some textures or to work it in to corners/crevices. I think a lot has to do with my own application technique though since others don't seem to have an issue. Black Wow is one I would say has "better than most" staying power and probably does a better job of "darkening" (even on neglected trim). It can get a little messy though if you get it on surrounding painted surfaces, glass, etc. ....I prefer the LSP approach but will still use dressings/protectants on some bits if needed.
Ultima Tire & Trim Guard is what you're looking for. Yes its on the expensive side at first BUT it takes such little product that in the end its cheaper.
What I posted above (about how LSP-based approach might not be right) kinda applies to the Ultima too though, doesn't it? I've only used Ultima on stuff that I've been able to get into decent condition :think:
I really like the stuff, but I don't see it working on something that needs its appearance *improved*; I see Ultima as a great way to keep nice surfaces staying nice.
Cee Dog has been doing some tests with it over on AG and it does an amazing job at improving the appearance on neglected plastic and trim. I too have had good luck with restoring severely neglected trim using Ultima.
Here is one of the pictures he has posted
PB trim restorer on left, Ultima Tire & Trim Guard on right
This is after 12 says with 2 rainy days. As you can see the Ultima did an excellent job at restoring the color. It does an even better job on black.
Been using UTTG as my go to trim protectant and very satisfied with the results. Recently tried GTechniq C4 and I must say I'm switching to C4. Have a full bottle of UTTG at half price if anyone is interested.
I am interested how much for the uttg
toyotaguy said:
maybe i shouldnt have added the add color. i want something that lasts!!!!
Well, if the "richer looking" bit of it *does* matter, then it matters (and if it doesn't...). I wouldn't want something nice and satiny-looking, nice and long-lasting too, on top of some gray, yucky trim that needs a different approach.
Maybe I'm just all worked up about the topic since I'm dealing with these new beaters of mine that're a LOOOONG way from the condition I'm used to dealing with! If the trim is in good condition that Ultima stuff lasts an incredibly long time, even with winter/etc. use.
Dubbin1 said:
Like I said Ultima is what you're looking for and it will add the color.
Guess this is a "YMMV" sort of thing. I wasn't thrilled with how it looked on the beater-Audi's rubber until I worked on it with Griot's Rubber Prep. I'll have to give it a try on something else that's messed up and see how it works.
I'm talking about plastic trim like the OP was asking about, I really don't know how well it works on neglected rubber. I'll have to find a car with nasty rubber and give it a try.
Eh, I guess I'm not being clear. I *was* thinking about plastic trim as much as rubber; the plastic rocker panel covers on my Crown Vic, the roof rack on my Tahoe...stuff like that. The kind of weathered plastic that I start fixing by working with Hi-Temp Heavy Cut. You know, whitish-gray, blotchy finish, rough texture...worn and sun-faded.
Anyhow, yeah...let's try some of the Ultima on not-so-nice materials and see how it works.
Oh, and just FWIW, on the Crown Vic I went at the rubber with that HiTemp Heavy Cut in the places where I couldn't use the Rubber Prep (which can't contact glass) and it worked very well. That particular polish/compound is great for surfaces where the usual "white staining" would be a nightmare, just don't let it dry before you buff it off and there's no problem.
I was impressed with Ultima T&T on black trim but the problem was that it after 6 months mine got funky in the bottle and didn't work as well.
