Don't steer away from exploring paths less traveled
ZoranC
Humans tend to subsconsciously travel paths they are comfortable with, which is often paths that others have went through easily with success before.
Many tend to follow "6.5" pad for general PC polishing, 4" pad for spot repair" well beaten path. I know how 6.5" pad on PC feels. My body is familiar with vibrations, sound, can see when it is bogging down.
Few months ago I came across 5.5" thin pads and product description was telling me they would be easier to work with. I am of a curious kind so eventually they ended up purchased down the road.
Yesterday was first time I used them and I am happy to say my curiosity paid off. There was less vibrations. PC was not bogging down. I was able to maneuver more precisely. I was very happy with results of my "experiment". So much that such pads will be my default choice wherever appropriate from now on.
Don't be afraid to explore paths less traveled. They are the only way to result in new rewards.
From the title I thought this was going to be some kind of yoga spiritual thing.
You know topics have been wandering with the cold weather and snow.
Always good to keep an open mind.
:chuckle: Well, on the serious side of that note, I tend to believe good philosophy and spiritual practices have to be grounded and in touch with everyday real life.
mose said:
Does anyone make a yellow cutting pad in 5.5"?
I think LC does, but I don't know who sells them (AG sells only orange and white ones, which is what I have).
However, LC makes their CSS pads in 5.25", sold through Danase, one of Autopia sponsors. I don't know how those work yet, but I do plan to find out, they are on my "to purchase soon" list.
Superb pads! The more I use them the more I like em. I also use the smaller 5.25 and 5.5 pads from AG and they're my favorite for the PC. They're the best balance of cutting, polishing with little vibration.
you know what, i hate them...my excel detail pads work a lot better than my 5.5orange LC pads...just the opposite of everyone else...only reason I have them around anymore is for extra pads to remove heavy oxidation so that i dont waste my other pads...I got the 6 for 30 buck deal a while back....
I walk on the other side of the path.... only 7.5" LC pads for me with the PC
just curious if you have been able to do any "serious" correction with 7.5" pads on the PC? i was frustrated even with 6.5" pads. once i tried 6" and 5.5" i never looked back. of course, for lighter stuff the bigger pads are better since you can cover more area faster. :)
Maybe you missed point of my post. It wasn't meant to compare particular pads. It was about how a) smaller pads are easier to work with, and even more b) how one shouldn't be afgraid to explore different paths.
Thank you thank thank you!
I have been trying to tell people that anything bigger than 6" pads is a pain. I wont ever use pads bigger than 6" ever again.
ZoranC said:
What is your reason behind it?
There are a few.
1- I got fed up with the velcro backing failing on a perfectly good 6.5" pad
2- The larger area = faster work (especially for final polish, paint cleaner, LSP)
3- LC 7.5" pads surround the backing plate which takes out the risk of the backing plate hitting the paint.
4- LC 7.5" pads are extremely durable. You won't find the backing separating from the pad
5- The variable contact pad reduces sling when used with a rotary
6- I can use the same pads for the PC and rotary
7- The PC is still very effective with larger pads.
budman3 said:
There are a few.
Try a pad that is 5"-6", just try it.
I cannot believe that a 7.5" pad does not bog the machine down. I used sonus DAS pads (7") when i first started out and they would bog the machine down with the slightest pressure. I cant imagine a 7.5" pad.
One thing to consider is that with a larger pad the outside edge is spinning at a faster speed so maybe that helps to break down the polishes better and work better. This would only be true obviously if the user was not applying pressure (slowing the machine) to the machine and using a technique more like one would use with a rotary. Just a thought.
Wish that was true but the PC dosent have enough muscle to spin a pad that size.
budman3 said:
There are a few.
Re # 1 : Would that be a failure of backing that has nothing to do with size of pad? Or it is failure directly attributable to size of pad?
Re # 2 : Smaller pad covers smaller area in one pass, but with smaller pad working more aggressively you need less passes, so wouldn't that more or less even out?
Re # 3 : Many highly experienced and reputable detailers, both here and on MO, prefer pad getting pressure on the edges. That is if we are talking PC. I have a feeling you meant with rotary. We were not talking rotary here.
Re # 4 : Does that mean that smaller than 7.5" pads from any manufacturer are not durable just because of smaller size?
Re # 5 : We are not talking rotary here.
Re # 6 : I too liked the idea of using same pads for both rotary and PC. However, if something will work better for me then something works better for me and I will not mind getting different pads.
Re # 7 : Why not go with 8.5" pads on it then?
However, if that was correct 4" pads wouldn't end up being more aggressive than 6.5" pads.
#1,3,4- The failure has to do with the velcro backing only being glued onto the pad itself. The edges of the velcro are constantly being abused (most of the time from removing the pad) and the glue wears down and the velcro backing lets go of the pad. It doesn't matter the size of the pad, its how it is made. The 7.5" LC variable contact pads have the velcro backing somewhat molded into the pad itself making it virtually impossible for it to separate. This is a big reason why I like them. I have a handful of 6 inch pads that have had the velcro issue and that is how I started using the 7.5" ones. Here is a picture of what I mean:
There is no way for the velcro to come off. This is what I mean in #3. The backing plate is surrounded by the pad. I'm not talking about pressure- on other pads if you drop the machine or tilt it at a bad angle, the edge of the backing plate could come in contact with the paint causing damage. That also won't happen with the LC 7.5".
#2- Yes the finishing on polishes would be quicker but it is still fairly fast with the bigger pads. Plus, as I said, you really gain when you use a light polish or glaze or paint cleaner or LSP... which is the majority of what I do for personal vehicles.
#5&6- Just an added bonus to the pads... I only use my rotary on very neglected vehicles and since I don't do this full time I don't use it a lot. So I am able to save money by using the same pads and they both work very well.
These pads are working very well for myself and many other detailers. I'm not sure why you aren't happy with my responses but I am just letting the rest of the people on the board know of the other options "off the beaten path". I have used various pads and the 7.5" pads are excellent- I see no reason to use any other size or type pads.
That is unless someone comes up with a smaller pad that looks like these pads, that wrap around the BP and the velcro backing is molded into the pad- then yes I would use a smaller pad. I agree that the smaller pads are more effective but it's rediculious to say that the 7.5" aren't effective (I didn't say that someone said this-- but it seems like it). Heck, it's only 1/2" on each side bigger than a 6.5" pad....
I have used these pads. I don't see any differences in the bogging or reduced cutting times. There's a reason why you can't believe it doesn't bog the maching down- that's because you haven't tried it. You can either take my word for it or go out and buy the pads to try and prove me wrong... I'm just sharing my personal experiences with pads and what I like. I do think that it is personal preference though. I like them, they are very effective, they last a long time, I can use them with 2 machines and they are safe. Sounds good to me.
