budman3 said:#1,3,4- The failure has to do with the velcro backing only being glued onto the pad itself. ... I'm not sure why you aren't happy with my responses but I am just letting the rest of the people on the board know of the other options "off the beaten path". ... I have used various pads and the 7.5" pads are excellent- I see no reason to use any other size or type pads. ... That is unless someone comes up with a smaller pad that looks like these pads, ...
Me not being happy with your responses is incorrect percpetion. I am actually happy to see different approaches and points of view and debate them, as much of your approach of going bigger as mine of going smaller, because thinking differently than beaten path is major point of this thread, like you too pointed out.
What I was trying to point out though is that I was talking about pad size while you were concentrating majority of pros for 7.5" on features of certain implementation that have nothing to do, like you too yourself said, with size. I agree that they are good features, but again would like to see that noticed and separated so it doesn't become apples and oranges. I feel it says a lot when you say you would go for 5" if you could find them with same features.
budman3 said:I have used these pads. I don't see any differences in the bogging or reduced cutting times. There's a reason why you can't believe it doesn't bog the maching down- that's because you haven't tried it. You can either take my word for it or go out and buy the pads to try and prove me wrong...
You are right that I haven't tried 7.5" pads to see will they bog down. I feel spending money to see whether that will happen or not would be a waste because if 6.5" ones bog down on me, like they sometimes do, 7.5" ones will, assuming they are made from exactly same material in exactly same straight edge shape and I apply exactly same pressure on them, bog down even easier, or to be precise 33.14% easier because that's how much surface area of 7.5" is bigger than surface area of 6.5" and resistance to movement (friction) is proportional to surface size. It might be just 0.5" bigger on both sides but 33% bigger is 33% more resistance. Of course, that is assuming they have staright edge. And if they don't have straight edge so their contact area is smaller than what ot should be based on size then what's the point?
