nlkccom
Do I know you?
I think KSG needs time to cure, but does KAIO need time to cure as well?
elk42 said:i apply the SG right after then i let it cure for up to 12 hrs before i wax.
armoredsaint said:i love klasse still, even though i moved on to zaino for curiousity.
and the longer you let KSG dry, the easier it will be to remove - apply thin also, i let it dry overnight.
psychadelic said:Dry overnight? Some say to apply it the Wipe On Wipe Off method (for easy application)
If you leave it overnight isn't it super tough to remove the excess?
btw, I love the AIO effect so far.
Anyone have a link to the Bill North Wipe On Wipe Off method?
Is it as simple as applying the sealant and wiping it off with a lightly damp MF towel after about 2 minutes?
armoredsaint said:i guess it's a personal preference, some like WOWO - but I like it to sit overnight - kinda like marinating it in the paint, never an issue with removal. remember to apply it thin. :xyxthumbs
didn't bill get banned? :nervous:
armoredsaint said:it okay to use a QD to help with the SG, i did it all the time -
i am digging Zaino, it's quite good - but all those steps is tiring. i brought the basically the whole line :clap: just finished up on my bmw today and s40 yesterday
RZJZA80 said:Klasse AIO doesn't need any cure time IMO, I apply wax over it immediately. Klasse SG does require cure time, depending on who you talk to, 12 - 24 hours, I think the box itself says over night or something like that.
Accumulator said:The little bit of "protection" (scare-quotes intentional) in KAIO that might benefit from curing are of such little consequence you'd never know the diff anyhow IMO.
As for the W-O-W-O technique (which I use when applying both the Klasse twins to textured black plastic), I don't even wait 2 minutes. Pretty much just on-then-off. Seems to compromise the durability just a little but makes for a more uniform appearance on the plastic surfaces.
psychadelic said:So how much of a difference do you see after 3 coats? So far really looking good after the 1st coat of SG.
Plastic Surfaces? Why would you do that? Does it help with appearance?
RZJZA80 said:I haven't tried adding more than 1 coat of SG so far, I just don't have the time to keep a car for that long to add so many coats
