imported_JoshVette
KH765 and David, thanks, it was a nice ride and a privelage to detail.
gmblack3a said:Nice work Josh. The black paint is really glowing now!
jsatek said:Is it available through GM?
_M_ said:they were around $71k, and its 594HP not 594RWHP (rear wheel horsepower), the LS2 is a great engine but they arent going to get that much horsepower at the wheels with relatively simple changes. probably around 500 at the wheels - still pretty awesome
MTI C6 Devil Ray 427 Conversion Pkg.
* 427cid "Super Stroker" engine
* MTI Stage III custom ported-and polished LS2 heads
* MTI DR1 custom camshaft
* New LS2 timing chain set and high-volume oil pump
* Jesel shaft-mounted 1.7-ratio roller rockers
* FAST 90mm intake manifold and MTI high-flow air intake
* Kooks 171/48-in. stainless-steel headers, 3" mid-pipe with high-flow cats, and Corsa Sport 211/42-in. after-cat exhaust (Corsa Touring exhaust may be substituted)
* Spec Stage III clutch with billet-steel flywheel (higher-stall torque converter for automatic cars)
* MTI underdrive crankshaft-pulley kit
* Complete gasket set utilizing steel-shim head gaskets, ARP studs, MTI hardened push rods, and all necessary fluids and filters
* Custom-embroidered factory seats and armrest featuring "Devil Ray 427" logo
* Custom Devil Ray decals and badging
* MTI fuel-rail covers with "MTI Devil Ray 427" insignia
* Devil Ray dash plaque with individual serial number
* Two-year/24,000-mile limited engine warranty
* Devil Ray 427 custom wheels (18x8.5-in.front, 19 x 10.5-in. rear)
* Professional installation and custom computer tuning on MTI's Dynojet chassis dyno
_M_ said:and its 594HP not 594RWHP (rear wheel horsepower), ...
jsatek said:Bro, at $71k thats a relative deal when you compare it to offerings form Callaway and Lingenfelter.
There is a gent on my street with a Lingenfelter 427 and he claims to have paid over $120k for it. Looks completely stock, I only found out because he came over when I had a Gallardo in the driveway.
yrebel7tpx said:how much does a detail like that cost
JoshVette said:Nice info, the owner told me that the rims in the rear were 13' wide though, I know they weren't 10.5' rims, they had on 325 and they barely fit, they needed to be wider tires.
I wasn't sure if it was HP at the wheels or crank, he didn't tell me, doesn't matter, it's still like 550HP at the wheels.:bow
6LS2 said:Dude, 594HP @ the engine is nowhere near 550HP @ the wheels.
Scottwax said:I have a customer with a modded C6 Z06 that put 535 hp to the rollers and was told that was about 590-600 hp at the crank. Supposed to get a ride in it since the mods, but he had eye surgery and can't see more than 50 feet in front of him when I was there last. Probably not a good idea to go for a ride with him, eh?
BigJimZ28 said:so they have there own chassis dyno but you you don't think it is 594RWHP (rear wheel horsepower)
why is that?
there is a lot more there then "relatively simple changes"
JoshVette said:Maybe you should do the driving then?![]()
