Preachers Sheets
This is the e-mail I sent to CMA asking if I would be able to get a new pad or if I was stuck with the one I have:
I have been using a CMA white foam pad for my Porter Cable machine and it fell apart.
I have been using the Porter Cable on speeds set at 5 and once in a while I have it set on 6. I do not apply any pressure because I am just using 3M Swirl Mark Remover for weaker jobs. I have used the pad for a total of 5 maybe 7 jobs at most. I used the pad last weekend in the shade (it was 70 degrees outside) and the foam seperated itself for the velcro backing. When I looked at the pad it was literally smoking and hot to the touch. I did however use that pad for 4+ hours non stop, I still have it un washed so I could show you. I did not change the pad because it was not gunked up with product yet, it was still working perfect.
Up until now I have never had a problem with your products but it seems there may be a fault with this one specific pad. I was never informed that I could only use a pad for a specific amount of time or at a specific speed for a set amount of time. I just thought I would use the pad until it needed to be swapped. There was no indication that the pad had to be swapped until it was too late.
What do you guys think, I was never told to use the pad in a specific way and I was not over using it because it didn't need to be swapped out. I would THINK I should get a new one...
Just a little peice of advice for you guys, if your going to use those pad's at high speeds, don't use it for more than 2 hours before swapping it out. If you ask me you don't even want the foam to get warm nevermind hot because over time it will weaken the glue.
