A phone call today with CMA confirmed that Blackfire's Scratch Resistant Clear Compound is not similar to SIP 3.01 or 3.02 - they indicated it was more akin to PG. Too bad, cause I needed to place a CMA order and I also wanted some SIP
If the above is true, I wonder if they simply used a ton of the same abrasive found in SIP, or if they used the "old" abrasives they used in IP & PG and simply modified the oils/solution?
