I never salt my food before tasting it - where is Henry Ford whenever you need a new job ???
Also been around long enough to see and paint with lacquers and enamels.
Before foam was invented all we had was different grades of wool and wool blends, and way back then, I learned to not swirl, etc., paintwork, and the Painter had to also colorsand and buff out the paint he just finished applying.
I think before 3M, Dupont made rubbing compounds as well as alot of the chemicals used in auto body shops.
Have always been open to changes/improvements, as I am sure we all are and welcomed foam, and velcro-backings because they were going to be easier to change, and removed weight from the end of the Rotary.
The only videos I have seen of this thing is some guy buffing the side of a Greyhound bus. I have never seen a video of a guy using this on a Porsche, Volkswagen Bug/Beetle, any small vehicle with a lot of curves, etc..
Not sure if I could ever afford one - much less the way higher cost of the belts it has to use (kind of like a big belt sander), and how long they last, how hard is it to change, you know, all that stuff.
As it stand today, with all the "improvements" to pads alone, the current foam pads I use on a Rotary, have a way shorter lifespan than any of the old-school wool/blended pads of the past, so I guess with newer technology, there comes the additional cost of replacement, or does that fall under "trade-offs"?
Also, not sure about lugging 11lbs on and off a vehicle X number of times is going to be a real time-saver or not for my needs.
All I can be pretty sure of today, is that any AutoBody and Paint Shop - you pick one - is still using Rotary Power, big, shorter nap wool/blended, etc., pads, and maybe the newer compounds of the 3M variety in the good shops and the also-rans, in the not so good shops..
Maybe, when I see them all changing over to stuff like this, I might get a little more interested - hey I like to improve my skills and products as much as the next obsessed Detailer !!
Until then - .:yawn:
Good luck with your new tool, Bud !
Next time I go see my step-son at the University of Portland, I will see if I can give you a call and perhaps if you have time, you can show me your new machine, ok ?
Dan F
DanF
