Breaking Zaino news...
Question....
mgm121499 said:
Scott,
Why reply to this thread so many times if you're not interested in Zaino?
Please don't say that you're interested in CS, Z-AIO, etc... because it's pretty clear that you've tried Zaino, liked it 'OK', but prefer to use other products. That's not a crime, is it?
Why not move on to other topics on the boards of more interest?
Answer....
Pennypacker said:
sorry...not to beat a dead horse, but if the reason why someone doesn't want to use product x is misstated or misrepresented by another poster, then it will tend to prompt a response.
Done!
mgm121499 said:
If you top zfx'd Z2Pro or Z5Pro with CS, you're adding (at a minimum) 50% to durability based on my uses.
Wow.....That's what I wanted to know....:xyxthumbs
CS can extend the durability of my already very durable Z5p and Z2p applications.....
That's going to come in real handy down here in Houston. Texas summers can be brutal and carnuba with that heat and humidity doesn't last very long. I'll have more time to play golf.......:D
When using ZFX you have to put a layer of ZFX enabled product every 6 months so if you choose to use ZAIO does that mean you have to use ZAIO every 6 months also? If you have to use ZAIO every 6 months that means you really need to strip all it down every 6 months and start over rather than just adding another ZFX enabled coat of Z2/Z5?
Let's keep this civilized guys. Didn't your grandmother ever tell you, "if you don't have anything good to say, then don't say anything at all." :)
farero said:
Can you apply Z-CS with a touchless system like an airbrush?
Best Regards.
Although I have not tried it in that method, I do not see the C.S. working in that manor. C.S. is applied very thin, and lightly worked in with the applicator.
Greg
looking forward to trying the CS, I scored some old school Zaino from a member in here to try... looked pretty good, but the process did not get a honest chance, as I appiled it in between the rain bursts here..(couldn't wait),
ok i'm a detailing noob and i admit i haven't read all 39 pages, but i was interested in going with zaino for my first detail. i've been planning on going with ZFX/Z5p, Z6, Z8 in the spring until i saw this thread. here are my questions:
1) where will ZAIO and Z-CS fit in? in other words, does it replace one or any of those products? or should it be used in addition (and before/after what)?
2) i've seen lots of mention about how proper 'surface prep' is essential for maximum results. what exactly is the proper prep procedure?
3) what is the general consensus on the dawn wash before first application?
Dawn wash is not needed, just use a paint cleaner (very mild polish) without any added oils before applying any of zfx, z1. z5 and/or z2...
Proper surface prep mostly involves the polishing stage. Claying is part of the prep stage, but not necessary for vehicles less than 3 years of age. Depending on the severity of your defects. the longer and more aggressive polishes you'll need...
If you have a near swirl free car (not likely), a simple z-aio & a couple layers of z5 is all you'll need. More likely you'll need multiple polishes to get the paint in excellent condition. If your paint has seen too many drive-through car washes, you'll need a series of polishes of differing amounts of aggressiveness.
Daily drivers may need either ZFX or ZAIO after 6 months "if" no product was applied in that time frame. After 6 months with zero care (excluding washing) most vehicles will need some sprucing up. Show cars or garage queens can stretch to a one time ZFX/Z1 and / or KAIO application to about year.
Apply a layer of Z2/5 within the 6 month daily driver usage and ZFX/ZAIO/Z1 is not required but after 8-10 it is recommended that either ZFX, Z1, or ZAIO be applied for maximal results.
Better yet, just lay a layer of CS if your finish is swirl-free and appearance is holding its own to your satisfaction and start Z2/Z5 if you choose later. This quik step will eliminate previous layer removal and set the foundation for whatever topper you desire. Basically ZFX can be completely eliminated from the system.:bounce
Since Zaino's new formulation negates the need to increasingly apply coats to achieve the desired look and normally 2-3 coats is max appearance augmentation. Using something like AIO every 6 months on a DD is quite reasonable to maintain a "show car" appearance and protection on a DD. Of course, if you live in a pollution-free environement these time-frames can be extended.:wavey
mgm121499 said:
Z-AIO is probably the 'least' durable product, but on par with any carnauba that I've ever used.
CS over 'bare' paint protects as well as a coat of Z2Pro or Z5Pro.
1 step up from that.... Z-AIO topped with CS.
Z-AIO and CS will be incorporated into many of my details this year. It really is an AWESOME combo, and the 'look' is right there. I'm surprised that Z-AIO hasn't been discussed more, because it's a very impressive product IMO.
Thanks John! I have done ZAIO on my beater and I think it looks very good, just some CS on a section of the hood. Will see how long it lasts with just QEW or Z7 washes.
I am detailing a good friends new car this w/e. So 2x of ZFX'd Z5pro, CS and Z8 should look outstanding and give outstanding durability.
blkZ28Conv said:
...Better yet, just lay a layer of CS if your finish is swirl-free and appearance is holding its own to your satisfaction and start Z2/Z5 if you choose later. This quik step will eliminate previous layer removal and set the foundation for whatever topper you desire. Basically ZFX can be completely eliminated from the system.:bounce Zaino's new formulation negates the need to increasingly apply coats to achieve the desired look and normally 2-3 coats is max appearance augmentation.
All the more reason to want to try their new advanced products! :up
Sergei said:
Ok Thanks Greg. So it looks more like this.
Here is a possible example of a full detail using Zaino:
#1 Z7 Wash or your favorite car shampoo
#2 Z18 Clay or your favorite clay
--If light swirls skip #3--
#3 Buff (hand or machine) per your favorite polish
#4 Final polish stage - use ZPC or your favorite final polish
#5 Z-AIO (replaces ZFX)
#6 Z-2 and/or Z-5 **NOTE ZFX unnecessary**
#7 Z-6 or Z-8 **wait to dry***
#8 Z-CS
From what I read, the jury is out on where Z-8 fits here. From those initial beta testers, Z-8 had a harder time setting on top of Z-CS. Right?
Quick Wash Detail:
#1 Z7 Wash
#2 Z-PC or Z-AIO
#3 Z-CS
ok i don't really get #3. first of all, i don't have a favorite polish since i haven't used any, but what's highly recommended around here? second, isn't Z5p a polish?
lastly, is Z-CS supposed to be replacing Z-8 or what?
OK, fundamentally these new products (Z-CS and Z-AIO) don't really replace any of the current line of Zaino products. They serve to augment the current line of products.
Step #3 in my description was in the context of a full detail. The point being if you have a situation where you have a car with medium to heavy swirls you need a product stronger than Z-PC or Z-AIO. Z-PC and Z-AIO provide some abrasives, but not strong. That's why I included step#3. From there you continue with Z-PC which has more abrasive qualities over Z-AIO. That is what is so powerful with these two additions. You can introduce other manufacturers polishes w/out interfering with Zaino.
In regards to Z-5... Z-5 has no abrasive qualities in the product - NONE. It has some fillers that act to optically disguise very minor swirls, cobwebs. Nevertheless, it's a great product that induces high gloss.
The quick wash detail example provides a list of products that assume you have a sufficiently good car with paint in good condition and you want to do a quick detail. The secret to Zaino is you have to prep the paint to accept the Zaino product. Anything short of that will yield sub-par results. Without good paint-prep, you will have a high gloss over paint that has defects.
As far as Z-8 vs. Z-CS... well I will leave that to those that have used these two in conjunction. I will guess, Z-8 topped over Z-CS. Right? Over to you beta testers....
Z8 is a spray sealant/QD that can be used to augment a protected finish. Z8 is not astand-alone LSP.
CS is a pure sealant that is a LSP. A stand-alone protectant that can be applied to a "virgin" finish and protect for months.
Example: wash-polish- and apply CS. Over the intervening months one can re-enforce protection, bump-up the "bling" and prolong the CS's durability by using Z8 after every wash or two.
Hope this helps. :wavey
shift_roro said:
thanks for clearing that up... so what then is the difference between Z6 and Z8?
I will use blk2z8conv's z8 description:
Z8: Z8 is a spray sealant/QD that can be used to augment a protected finish. Z8 is not astand-alone LSP
Z6: Quick detailer with no protective properties.
Greg
Sorry, but I do not agree with this. I have used clay on brand new cars and gotten some pretty bad stuff out.
Also I think some are misinterpreting the use of ZFX (or I am). As far as I understand ZFX is a catalyst for Z2Pro and Z5Pro....that is it speeds up the curing of those products. I don't think you ever use ZFX alone. None of the new products will eliminate the option of using ZFX to allow for multiple applications of Z2/Z5Pro. Correct me if I am wrong.
ZFX will be needed for multiple coats of Z2 or Z5 in one session with max being 3 coats.
ZFX will be necessary for initial coat if not using Z1.
ZAIO wil allow 2 coats in one session (ZAIO and Z2 or Z5)
ZFX is not necessary if one is applying one coat over cured CS. I would wait 24 hours after CS application.
Yes, I agree claying can and should be used on any vehicle that has embedded debris. New or Old.
I will be doing some testing later this week using a Zaino carnuaba sandwishing technique.
ZAIO/Z5-ZFX/CS (cured for 24 hrs.)/Zymol (cured for 24 hrs)/CS( cured for 24 hrs)/Z2pro.
Vehicle(Millennium yellow Z06) not driven during these applications.
Initial testing with Z5/Zymol/CS extremely promising so far. No incompatiblity noted.
Right. ZFX is still to be used if you want to add more than one layer of Z2P or Z5P in a day. ZFX doesn't make Z2/Z5 dry faster, but it makes it cure faster (bond within each layer).
Eh, I am not seeing the greatness of this if you still have to use ZFX with Z2/Z5 to get descent durability. To get descent durability you would still need the ZFX'd Z2/Z5 topped with CS. I wish CS would be great as a stand-alone and have similiar durability to Z2/Z5 alone. Unless, if, adding CS to Z2/Z5 is sort of like creating 100% more durability.
