Breaking Zaino news...
Scott,
I have and use Prime and Prime Strong. Without sounding bias since all these products (KAIO, Prime and PS yield excellent results, I like the appearance and cleansing ability of ZAIO better. Could be that initial polishing was done with Z-PC Fusion and the ZAIO was removing Z sealants from the test area.:nixweiss
I also have some Opti-Seal to try this week. :D
Scottwax said:
John-I know you've used Werkstatt products, how comparible is Z-AIO to Prime?
Scott,
I've never used Prime as an All-In-One (i.e. as a stand alone LSP), but I do think it does a good job cleaning the paint.
The latest version of Z-AIO also cleans well and leaves a very slick, high gloss surface.
Z-AIO durability is on par with any carnauba product that I've ever used in the Northeast
-where we get salted roads and plenty of acid rain.
Today is no different, except the acid rain is coming down in the form of snow. Am I venting? (LOL).
Hope this helps.
Did I miss a page somewhere? When will this be available? I don't see it on the Zaino Home page. Thanks
mgm121499 said:
Yes, I have used Z-AIO for a few months.
Here are my thoughts....
Z-AIO was shipped(TEST SAMPLE) in a 2oz bottle, identical to the ones shipped with zfx.
2oz was enough to polish out 2 mid-sized cars. You will use less product by hand.
Z-AIO was applied to virtually all external surfaces (paint, glass, plastic lighting, wheels, painted and flat plastic trim, jams, and a few areas in the engine bay). I didn’t pick up any staining.
Z-AIO was able to correct very minor marring, on par with Klasse-AIO which is arguably the most popular one-step product.
Z-AIO doesn’t have the cutting abilities needed to level swirls. If it did, I think you’d be looking at a 2+ step process, which would defeat the purpose of using an all-in-one product.
Z-AIO ‘cleaned’ the paint surface effectively, didn’t dust (I primed my pad with Z6), and wiped off with very little effort.
Z-AIO restored the paints original luster, and left behind the ‘trademark’ Zaino shine and slick surface. On older paint, you really notice the renewed luster.
Z-AIO does not require zfx.
Final Thoughts on Z-AIO
*An excellent choice on new, or well maintained paint. It works well on blemished surfaces too, but isn't intended as a swirl/defect remover.
*Safely removes ‘clay bar’ marring.
* Saves Time, and provides a solid 'base' for Z2Pro, Z5Pro, and CS.
I plan to use Z-AIO and CS on many details this year. They work very well together, save time, protect well, and leave you with a killer looking finish.
Great write up.......:xyxthumbs
Question for combo's.....After a Z-PC polish with a LC white pad, should I go ZAIO and then Z5p and ZCS......or.......a polish and then ZCS and Z8....?
Use ZPC for swirl removal and all other Zaino products can be used depending on your preference.
ZPC/Z5pro/CS
ZPC/Zaio/CS
on a flawless finish
Zaio/Z2pro/CS
Zaio/CS
Z8 for extra gloss boost after washing
It sounds as if using both ZAIO and Z5pro is a bit redundant
another noobie question... is it normal (or recommended) to use a polish (e.g. OP, ZAIO, Z5p) or LSP (e.g. Z8, ZCS) on glass? i'm particularly looking for something that will bead rain on the windshield, w/o streaking, to replace my current bimonthly rainx treatment...
Z8 works well on glass.
GregCavi said:
CS: can only be applied by hand
ZAIO: polishing or finishing pad.
Greg
ZAIO can be applied by hand too -but I agree with all of the points raised by GregCavi.
Don't think of ZAIO as an abrasive polish that will level out defects -it will not. It will take care of very minor marring, but that's about all.
I like using it as a finishing polish:
-You get protection, don't have to use zfx, can top with Z5Pro, Z2Pro, CS, Z8, -OR- your favorite LSP topper.
I really like the combo of Z-AIO topped with CS.
mgm121499 said:
Z-AIO and Z-CS will be released on Wednesday Feb. 7th
As for packaging: Z-AIO = 16oz, and C-CS = 6oz.
Any guess on the price of CCS?
I cant wait to try it, but will probably wait until spring when I do my full detail (paint correction and all) if it's as expensive as I think it will be.
