imported_Flash Gordon
IWhat is wrong with the Poorboys SSR polishes? I was considering SSR 2.5 and SSR 1. I don't really see how either is going to mess anything since both have less cut than 105. Could you explain? I am curious
You tell me and we will both know. I was sent samples of ssr1, ssr2, ssr2.5 back when they changed there formula. To make a long story short, I used these products on a black Mercedes. Each step I took the paint got progressivly worse. I finally had to abandoned the ssr and go back and redue the entire car using Megs/Menzerna :wizard:
As the old saying goes, maybe I got a bad batch
Some more food for thought. When is the last time you have seen a profesioinal detailer use the SSR line? I can answer that in case you can't NEVER
BTW. No direct links to competeing forums. I'm sure you understand Da Rules!
