imported_weekendwarrior
I have seen threads where some of you guys mix Z-PC, and Z-AIO together to get a little correction via the PC. Does the Z-PC/ZAIO mixture provide enough of a "base" for Z2 or Z5 to bond to, without having to use Z-FX?
I know that you don't have to use Z-FX if you are applying a layer of Z2 or Z5 after applying Z-AIO, but I wasn't sure if mixing any Z-PC in with the Z-AIO changed that.
Also, what amount of Z-PC are you guys typically mixing in with Z-AIO?
