Additional Uses for DA
Todd, how are you cleaning shower tile? You have peaked my curiosity....
I have used light polishes, like BLACKFIRE SRC Finishing Polish, with a microfiber polishing pads, to lightly clean the tile... I have also used microfiber finishing pads with CarPro Spotless to increase scrubbing power.
Do I need a different backing plate than the Lake 5" DA in order to use brush pads for carpet cleaning?
Cheers,
Van G
My Harbor Freight DA is going on two years now and I'm happy. It's done several boats in bad shape and does maintenance on my fleet. I recently used it to buff out a fiberglass shower/tub insert in a bathroom i freshened up for the arrival of our first child. Came out great. Planning on using it on my boat carpet this year.
That depends on how bad the soap build up, etchings etc. are.
I start with Carpro Spotless then (if needed) LC white foam & M101/M205
You can then put a good sealant or coating on the glass once it's polish.
Yep, gonna try this! Was this acrylic or actual glass? I believe my shower door is obscured acrylic. Do you think that pad is still ok for paint use?
All the way back to the wood sanding comment. I`ve never tried it, but it is my understanding the PC was first a sander then detailers started to use it on paint. So I`m guessing it would be fine on wood projects. And I would buy 2 of the 6 packs of pads. You never have too many pads. 4 is not enough.
