On the fence whether to purchase DA or have someone correct/polish cars before applying OC2.
What other uses for the DA do people have around the house/shop?
what do you use to polish the shower door glass. boy do i need to do that
Putting together my order for the 7424xp. I'm buying it with the Lake CCS pads (2 orange, 3 white). Going with Optimum Polish II and Compound II to prep for OC2.
What other accessories should I look at for carpet cleaning and polishing around the house? backing plates, brushes, pads
Is 3" plate/pads worthwhile for paint correction or alternate uses?
Should I think about more/different 6.5" pads?
If it were me...(to start) I'd go with...
5" backing plate
Meguiars Mirror Glaze W67DA G110 DA Polisher 5 inch Backing Plate
Lake Country 5 1/2 Inch Flat Pads 6 Pack
2) Orange 2) White 1) Black 1) Blue
Correction Polish
My favorite "swirl killer" combo.
Meguiars DMC5 DA Microfiber Cutting Discs, 5 inches
and
Meguiars D30016 DA Microfiber Correction Compound 16 oz
Pad on-the-fly cleaning tools
For the mf discs Safe Scrub Bug & Tar Pad
and
For the Foam pads Meguiars Professional Pad Conditioning Brush
Finishing Polish
CarPro Reflect Polish 250 ml.
This would be my (machine, pad, polish) "starter" list.
Did I mention that high QUALITY microfiber towels are VERY important?
"I once put holograms in paint just to see what they looked like...Stay swirl free my friends."
Seal with ????
What do you use to seal the plastic enclosure and tile - a polymer sealant? Does it discolor the grout?
If you have any projects that require sanding/polishing, a DA is super handy. I also use mine to clean my shower tile, polish water spots off my show door glass, clean my stainless steel appliances and scrub my carpets.
