Originally posted by blkZ28Conv For best results use as directed and at no place have I read officially that Z6 should be or recommended to be diluted.
JMHO
Z6 Lite[/B]
RIC said:The rationale behind diluting Z6 first began because many people had difficulty using it on hot surfaces and/or in strong sunlight situations. It just dried too fast. It would smear. And you would end up using more product thereby wasting it.
The best solution is not to apply it to hot surfaces/in direct sunlight but we all know that sometimes this may not be possible for a variety of reasons.
Someone who used Z6 discovered that by diluting it with distilled water it became easier to work with. The additional water allowed it to spread on a larger area and made it more economical to use.
It is not a protocol nor a necessity. I see no irony in diluting it when using it on a hot surface or using it full strength when adding another coat of polish.
The water evaporates so fast that it will have minimal impact, if any, on crosslinking and enhancing gloss. I highly doubt that any QD product adds any significant amount of protection.
As far as Clearcote QS, Sonus Acrylic Spritz, Pinnacle CM there is no way to to compare the concentrations of their active ingredients with those of Z6 to begin with, unless you have some kind of scientific equipment.[/B]
