Z-PC and Z-AIO, why would you need both....
Paulie Walnuts
Long time Zaino user here, curious, why would you need ZPC and ZAIO. ZPC is supposed to be a prep to Z2/Z5/ZCS, why would you need ZAIO also.
I dont plan on buying these because I have other products, just curious.
ZPC is a stronger Polish and works on swirls and defects better. ZAIO is strictly an AIO...Not quite the same polishing abilities.
Right but if you used ZPC you would not need to use ZAIO being that ZPC already is prepping the surface. I guess that it the point I was trying to convey.
zpc polish is a perfect finish polish and the gloss it gives is amazing. A little goes a long way. One of my favorite finish polishes.
ZAIO is also perfect for those quick and easy clean ups in one step. Plus you can also put on a coat of z2 or z5 without zfx or even top with cs. Very easy to use, plus it makes most trim look great too. No powdery mess niether with very easy clean up.
I always use both often or one of them for every detail I do. To me they are a must have in my book. That's my opinion!
Zaio was created for those wanting a 1 step product or who don't want to use ZFX(ZAIO/Z2pro or CS). CS was designed to offer WOWA convience without the need for ZFX.
After using ZPC for defect removal, I think Z-AIO would be a excellent base for Z2/Z5 (whether ZFXing or not).
Right, ZPC will prep the surface for z2/z5/CS, and you don't necessarily need ZAIO. I have found ZPC to be mildly aggressive on softer clears, depending what pad is used. It also works great by hand! ZPC also does a great job on my stainless steel exhaust.
FWIW, I use both and for me one does not replace the other. I love ZPC, and I love ZAIO. Ooooohh I love ZAIO.
