Scottwax said:Regular brake dust build-up, even if it is heavy is easily removed with ONR. Next time I run across a really filthy wheel I'll either take pictures or video the process.
lecchilo said:For all those ONR users, I would really love to see a video of the wheel/wheel well cleaning as well as washing off dried on mud/dirt from after it rains and sits a few days... a hose or powerwash gets most of the stuff off fairly easily and I don't see ONR doing it effectively... I would assume the only way to do it would be as with bugs, by leaving the towel with ONR on top of the mud to loosen it and lift it, but that's a huge waste of time when you can just spray it off...
Scott, the video you have up shows the process well and obviously leaves a great surface, but that paint is very clean to begin with.
Don't get me wrong, I started using ONR recently on my M3 as it never really gets dirty, unless it rains hard and I let it sit for a day or two after a rain, so it's not like I'm bashing ONR, just thinking out loud that it has its limits...
Dsoto87 said:Harder how?
On my own car I don't even seal/wax the rims since whatever ONR leaves behind let's me just wipe away the break dust at the next wash. I can't remember the last time I used a dedicated break dust cleaner on my own car.
Dsoto87 said:Could it be a possibility that its the 425? Do you spritz it also when you clean them with a regular shampoo?
Just wondering why your getting this with ONR incase I ever come across this situation.
Edit: what wash media are you using on the rims? I found that short looped mfs worked the best for me.
Accumulator said:The brake dust takes more effort/shampoo mix/time to wash off. It's simply tougher...like it adheres to the wheels/tires more for some reason. This is a consistent issue for me, happens every time I ONR my wheels/tires between regular washes :nixweiss
Additional info: the wheels are all well-LSPed with various products, the tires are both dressed (Z16) and not. The ONR is mixed with di water and I've tried various strengths. I've tried different QDs (also tried using none) after the ONR washes to see if that makes a diff and it didn't.
I have different brake pads on the various vehicles in question.
FWIW, my conventional wheel/tire washing is almost always done with shampoo mix (not Wheel Cleaner) and goes *very* fast and easy, even when the wheels are utterly black with dust; it just washes off with minimal effort. I suspect that's part of why I notice a diff at all.
Don't take this as a slam against ONR or anything like that..I like being able to clean the wheels/tires without worrying about getting any overspray on the rest of the vehicle. I just wonder why it works out for me the way it does :think:
TortoiseAWD said:You only wash a panel or two at a time, then go back and dry those sections. With ONR, you shouldn't ever run into water spots because the wash solution doesn't have time to dry.
And, since we're talking about ONR wash methods . . .
I use an old Sonus buffing towel (microfiber, but feels more like cotton terry) as my wash media. I get the bulk of the dirt off of a panel with one side of the towel, then flip to a clean side for my final wipe on the panel. Then, to dry, I use two MF hand towels. One is dampened with ONR solution (dunk it, wring it out as much as possible), the other is just dry. I use the damp towel first, for two reasons: First, with our hard water, anything but brand-spanking new MF just doesn't absorb quickly until it's damp - it tends to just push water around. Second, I figure the damp towel has at least a little lubrication to it just in case I missed any dirt with my wash towel. Then, to finish, I follow with the completely dry towel to get the tiny amount of wash solution left behind from the damp towel.
FWIW,
Tort
Dsoto87 said:Being in texas, onr is made for people like you. Mix 2 gallons of distilled water and you won't even have to touch your car to dry. As long as your wash media is removing everything than it will dry streak free.
CocheseUGA said:Who uses two buckets, and what is your reasoning?
D'oh, sorry. Reading comprehension > Tort.yo2tup said:Yes I understand that, I use ONR on a regular bases. My question about water spotting was directed towards to bolded quote below.
