vtec92civic
nice garage. i can't wait to hopefully be able to afford a house one day and trick out my garage!
Meghan@Autogeek said:This is turning into a serious Man Cave, no longer a garage!
rexrock said:Be careful if you get that flooring wet or get any type of dressing on it, gets a bit slick. I have the same flooring but in the 'lined' pattern. Works well and looks great. Good luck.
DETAILKING said:Looks good! I am also considering the roll out flooring. If you can live with the ribbed pattern, the local sams club has it for dirt cheap. The ribbed pattern isn't my first choice, but it would handle water good if you pulled a wet car into the garage.
The only issues I have read with it are that hot tires can stain it (lighter colors mostly), and it expands/contracts/moves when temperatures change (winter / summer), so if you have heavy objects on it it could buckle a bit when the temp changes.
I agree, the roll out flooring is better than tiles if you are ever going to have a wet envronment.
