kkjv1 said:Will a finishing wool pad leave less hologramming than finishing foam pad using the same finishing product like Ultrafina SE?
Bigpikle said:...and how do the least aggressive wool foams compare with typical foam polishing pads - ease of use, cut, ability to finish etc?
thanks
thanks
TH0001 said:I have a question...
Wool seems to cut quicker (i.e., it only take 45 seconds or so for SIP to breakdown on a purple foamed wool) than foam. I wonder what makes wool "seem" to break down the abrasives faster then a comparable foam pad.
I still haven't really tried any of the Edge Wool pads (except the System One style, which I heard is equal to the black wool)...
bert31 said:Based upon the numerous threads I have read on here, traditionally, a wool pad will leave less marring than the equivalent foam pad. The exception may be when it comes to jeweling the paint as TH0001 was described on here using Ultrafina SE and as SuperBee has described when using Menzerna's lightest abrasive polish. I cannot remember what that polish is called at the moment.
bert31 said:The thread SuperBee states that Edge White Wool polishes just as much as Lake Country White Foam but finishes better. I hope SuperBee can jump in and give more info.
A light cutting wool pad cuts similar to a light cutting foam pad.Bigpikle said:this is one of the most interesting threads i have read for a long time - I had assumed that all wool pads were going to give MUCH higher levels of cut than foam pads, so were to be used by experienced users, with caution and to eliminate severe defects only :wall
The best system for hook and loop is without a doubt the Meguiars solo pads. 7inch is an awesome size and it uses wool for cutting and foam for finishing. Pretty much the only system that uses the correct material for the job.Bigpikle said:Now, can somebody please help me work out which pad system etc I need? I already have a 3M backing plate, so are hook and loop systems worthwhile or is it better to use pads like the S2000 system or other options?
TTWAGN said:A light cutting wool pad cuts similar to a light cutting foam pad.
As the cutting foam pads often dig in and can create holograms then a wool pad of similar cut is actually safer.
+1. As long as you don't overwork your polish, and you use enough for a wool pad (it takes more polish when using a wool pad to do the same size panel than when using foam), you will likely see *less* hologramming after cutting with wool than foam.
A finishing wool pad is pretty damn awesome for most paints. However you reach a point where wool cant get any softer and it can still marr soft black paint. Thats where foam can be good for final finishing.
+1. Finishing wool is fantastic on really hard clears. Also, the better lubed your finishing polish is, the better the wool will finish out. *Really* well-lubed finishing polishes like PO106FF will allow you to finish the wool down much finer than a lesser lubed product. The jury is still out on Ultrafina's ability to finish down well with wool.
I find that i can often finish with less hologramming using the light cut wool compared to a polishing foam that has half the cut. Cuts more and finishs better.
+1. And runs cooler.
If you plan on doing a lot of cars then moving to the Edge 2000 system is definitely a good option. I reccomend getting the smaller 6inch pads for the cutting and then 8inch wool for finishing. If you do atleast one car a month then the Edge 2000 system would be the way to go. The edge pads last longer and are cheaper considering they are double sides so in the long run the large change over cost will pay for itself after a dozen cars.
+1. Except I don't like the bigger pads for some reason. I stuck with the six inch pads. I have the entire Edge line of wool pads, and have been very pleased with them. I do, however, use LC's 6.5" Purple Foamed Wool pad as my go-to pad for medium correction.
Bigpikle said:TTWAGN - thanks for the great advice. Megs UK is just up the road from me, so may well head up there and pick some stuff upIt sounds like they might be a good way into the wool method, with lower initial cost, and i dont do a big volume of cars, so probably no big drawbacks.
so with a light cut wool, and a polish like Mystique/3.02/Megs 83, can you give me some tips on speed and number of passes? I would normally be running at 1800-2000rpm max speed during cutting and doing about 10 passes for max correction, before slowing down and refining for a couple of passes.
How does the technique for these wool pads differ - sounds like probably a lot fewer passes are required to get the correction?
many thanks
SuperBee364 said:Is the new Meguairs So1o line of pads available in the UK yet? They've been getting really good reviews so far. Their process is more along the lines of conventional usage of pads; wool to correct, foam to finish.
SuperBee364 said:PO85RD... NOT PO85RD 3.01 or 3.02.
mose said:So can wool pads be used with something other than a rotary (i.e. FLEX)?
TTWAGN said:A finishing wool pad is pretty damn awesome for most paints. However you reach a point where wool cant get any softer and it can still marr soft black paint. Thats where foam can be good for final finishing.
