Yamaha0219
I'm getting my 2005 white F-250 tinted as we speak. I talked to the guy at the shop this morning about what I wanted and he just called me with some questions.
The truck is a crew cab, back two windows and rear window has 25% (says the guy at the shop).
I told him I want 18% on the front, the back adjusted to match the front (or back a little darker), and the rear to end up with a limo result (all within reason).
He just called me a little confused, he said that he usually doesn't deal with people wanting a 'finished' percent, they just say they want x% of film.
My opinion is that if you're a reputable shop you should be able to figure out what percentage you need to use to achieve the desired results for the customer. After his phone call I hopped online and found out how to calculate tint % (probably should have done this prior to going) but I figured an expert would have had no issue achieving what I wanted. So I'm a little worried to see what the result is later today when I pick it up.
My calculations:
Rear: Has 25% add 35% = 8.75% result
Back: Has 25% add 70% = 17.5% result
Front: Has nothing add 18% = 18% result
Granted I'm no tint expert, maybe I'm missing something here and its not as easy as I thought....
I'll post some before/after pictures later
My calculations:
