White camaro fine swirl marks
jclt12003
1997 camaro LT1 M6 T-tops
Hey guys before winter i am going to detail my car one or two more times before i put it away for the winter. I was wondering if anyone would suggest using the Poor boys SSR1 or SSR2 now i'll be putting it on by hand i really don't trust myself yet with a buffer. I was thinking about getting if buffed locally by a body shop. Now the swirl marks are not that bad at all. I just want to get out as many as i can. I used scratch X last time and it worked pretty well. But i was wondering if the SSR1 or SSR2 would work better. Thanx
Jason
The SSR2.5 will cut pretty well but you are going to want to polish after that...the SSR1 acts kind of like a polish and SWR so most of the time you need not followup with polish...On white because its forgiving of swirls I would use the SSR1 and then followup with wax
would you use a paint cleaner after this then seal it. Like a poor boys polish and then natty blue. I am kinda new at this so i need some help thanx guys.
Jason
If you have pro-polish then after the SSR I would do that then seal, wait 24 hours for cure time then wax....if you want you can do straight to wax after the polishing stages its your choice
for maximum protection, after you get done using SSR 2.5 and 1, i recommend topping the car with poorboys polish with carnuba(blue). wipe it off and then apply poorboys EX-P or EX. wait 24hrs and then apply poorboys nattys(blue). then put it away for the winter. good luck
