When should I wash/trash a polishing pad?
Davidss
Hi I've been using a PC for about a year now, I've done maybe 1/2 a dozen car and am really getting the hang of it. One question I've always had is:
How do you know when you need to wash a pad?
What is the best way to wash/dry a pad?
When is it time to throw away a pad?
Thanks autopia!
After detail, you don't want to use dirty pads.
Search is your friend as this has probably been discussed several times.
I use dishwash detergent for handwashing the pads, good rinse/press out excess water and left to dry.
Use common sense, most pads do work ok even though they look bit worn.
:welcome to Autopia Davidss.
- Usually I'll wash my pads after a detail and if they get pretty caked on during a detail, I'll wash them.
- For me, the best/cheapest way to wash my pads is fill a bucket with a little bit of Dawn and water and massage the product(s) out of the pads.
- You can kind of tell when it's time to throw away your pads. Usually that's characterized by varying degrees of pad wear such as: deteriorating foam, backing separating from foam pads, etc.
I hope this helps.
Davids- Welcome to Autopia!
Most polishing/finishing pads will last a good long time. Cutting pads sometimes wear to the point that they become more gentle, which may or may not be a big deal depending on what you're doing with 'em.
Thanks for the info guys! I have searched a lot and there is some info on how to wash pads but not much on when to wash them. So can I make it through a whole car without washing a pad?
Welcome Davidss,
I use 4" pads and following advice I got here at autopia I change my pads while polishing. This means I am using a hand full of pads by the time I am done (I switch to new ones when they start getting built up polish, or if they get dirty or something). I wait till am all done polishing for the car and then clean all of the dirty pads.
I am using Dawn Power Disolver to clean then (search, as its been talked about a lot here). Works really good. After they are cleaned I let them air dry usually, though I just did a few in a dryer run on low heat as I wanted to use a few again pretty quickly. I then store then in plastic bin waiting to be used again.
I haven't been detailing long enough to wear out a pad. So I am curious how long it will take me to get through my first batch of pads.
chris
