What would look best on a medium blue?
Rave'nGTi
I've got an 03 Audi TT on the way and its Ocean blue (similar to the old Denim blue)
I've been using zaino on the GTI.... but I'd like something deeper/wetter with more pop. Things to consider: I have no garage, I'm in the desert, and the car is mostly in the sun all day.
I've considered liquid souvern (sp) since there was a picture of a blue nissan pickup on CMA's LS page thats similar in color to my new car... and I've also thought of blackfire...
any others I should take a look at?
You are in the desert..... then you must get some Clearkote vanilla moose hand glaze. this stuff rocks and will give you the look you want. I use it on all my cars and customer cars. you should also look into the quick shine as this is one of the best products ever made.
if you get a good day i recommend topping of with s100 if the sun allows you to, otherwse moose wax
NYD
hmmmm...........Desert, no garage........My .02 is opposite NY's. I'd undoubtedly go with a polymer.....Petroleum and Carnauba based stuff is good up to surface temp of about 175 deg's, then it evaporates or breaks down...Platinum or BF II would be my toxin........Scottwax uses a different Poly, but my baby would be protected with a poly all the way.....Not knocking Clearkotes stuff, I have those prod's too, and they are good, Quickshine is awesome....
And not to knock NY's opinion or work, from what I hear, hes quite the "tailer"....
