Accumulator said:Yeah, that's right. Though I've been using a slightly stronger mix recently (~6 oz. shampoo/gallon).
chefwong said:I would say no. Maybe if it's lower area but the gimmour gun is not a pressure washer ;-)
The soap mixture can be adjust on the go so it's not a hard set rule on the soap/water solution you have in the tank as on the bottle itself, the settings go from 1-6 oz per gallon via the soap gun.
chefwong said:Found any new carwash soaps you like or it's all Griots for you as well these days..
