No tire salve - here. Just a little leftover QD
1. saturate entire tire, even tread with low-med mist move to wheel well move in to wheel face then caliper and inner wheel out of the sun if possible
2. apc/simple green 20.1 with fine mist sprayer to wheel well, tire face, wheel face, inner wheel, caliper real good
3. spoke brush, pre-wet w/water, scrub inner wheel, rinse brush immediately
4. face brush, pre-wet w/water, carefullly do wheel face, rinse brush immediately
5. tire brush, no pre-wet, just make sure the apc is still wet or re-apply around tire then just a quick once or twice over, until you can see the dirt lifted off and ready to be rinsed away, rinse brush immediately
(( I've just found it better to rinse the brushes BEFORE they dry ?? ))
6. rinse tire, wheel face, entire wheel, wheel face, tire with a ultra fine mist, turn up pressure as you go to low-med mist working your way out to the wheel well
7. 425/QD du jour moisten the center of a COSTO tossable mf, get the wheel face, spokes, if possible, inner wheel, caliper, nooks and crannies. Quick pass or two over the tire face, wipe down the wheel wells, pat down any water spots on painted areas.
that's it
optional steps
8. Polish/wax wheels, remove defect
9. Tire Dressing
Doing the 'tires' first lowers the ambient temp of the vehicle.
that's it
optional steps
9. Tire Dressing
