What final polish after using Menzerna PO106FF?
Experience tells me so. These polishes will accomplish the same finish if used on a perfect surface. The difference is only in how much cut they have. They both finish with a 5 on Menzerna's chart.
What I meant is why you feel it is unlikely it was because of not having another pass with 106FF?
Well i did my whole truck wit ha white pad should i do the whole truck again using a black pad to finese the surface even more? Or was it ok to stop at the whitepad.
That's answered in the quote. If they finish the same then there is no need to follow one with the other. It's like topping P21S with S100.
Is there any hazing in direct sunlight? Have any pictures if you don't know what to look for?
Yes it seems there is a very slight hint of hazing but only in DIRECT sunlight. Other than that the surface looks like a shimmering lake.
if you guys already had 85RD in your garage, would you get FP or still get 106ff?
i only have IP and 85rd and i don't think it's strong enough as far as cutting...
I think I have miscommunicated my question here but that's OK.
