imported_FJF
GoCubsGo said:Which Surf City detailer....Speed Demon or Hot Rod?
Hot Rod. It's very similar to 425.
2clueless said:Hey guys, newbie here.... I've been reading different posts about QDs and have gotten an impression that the top two "professional" products here are FK425 and OID. Followed by the OTC Meg's Quick Detailer. Would you say that is a fair assessment?
So the question is, does the color of the car make a difference as to which product to use?
I'm trying to figure out what to use for myself. I have a white BMW and have been using Optimum Car Wax after every wash (once the car is dry). I'm thinking if I should continue to use the OCW or switch to using FK425 or OID.
Also, do you apply/spray the car with a QD while it's still wet? Or do you dry it first, then spray the QD? If you spray first, dry second, then what towel do you use? The reason I ask is because I use Waffle Weave Drying Towel to dry after a wash and quality Microfiber Towel to wipe off the OCW. I don't think microfibers are good for drying and I didn't think Waffle Weave Towel is good for wiping off QD. Please set me straight.
Thanks....
Fallguy said:OCW and a QD are apples and oranges as far as what they are made for. You can use either , but they serve different purposes.
FJF said:Hot Rod. It's very similar to 425.
Dsoto87 said:I haven't used the CG stuff but I will tell you that OID is pretty direct replacemnt.
There are a few details though that are slightly different.
If FK is a 10 in gloss, OID is a 9.
If FK is like a 5 in cleaning power OID is like a 7
If FK is 8 in ease of use OiD is like a 9.
So you lose very little gloss but gain some cleaning power and its slightly easier to use.
Btw the #s I just posted are just for comparison purposes
wagonproject said:Anyone use this?
Rx8 Fanatic said:Thanks. Will the OID remove any trim protectants if sprayed on after? I use FK108 on my bumper trim and when I QD the car with 425, it still keeps them very dark and matte after. I am basically asking if it will clean too much to the point where it will remove the proetectant. It probably won't be that big of a deal thought if it keeps the finish dark and matte.
Rx8 Fanatic said:Which one has more slickness, OID or FK425?
blucpe said:imho there's not alot of difference but i'd give the edge to 425, try surfcity garage hotrod detailer as good or better than 425 imo.
superchargedg said:Sorry as surf city is decent but is no were close to FK45.
