minerigger
That is the plan for the spring detail. Unless I go a different route?
Do you want another bottle go free? I used it once to do my work truck.
It felt like it, and I`m glad they payed more as it took longer than I said I was gonna doOMG! Priors looked like a day care on wheels! Looked like a crime scene!![]()
Since I’m in an underground garage with limited lighting, I’ve been searching for lights, the past couple years.
Found some finally !
I picked up the 60w. 100w. and the 150w. LED
The 150w. Was like opening a wall and letting in the sunlight !
Before
After
I had to also pickup some L brackets to mount them to my stands.
Thought I would ad some pictures from the tar mess LOLDecon washed the Ford Focus I maintain. Man this tar build up makes me crazy soon LOL. Even with a great product like Carpro TarX it`s not desolved in one go with it. And the second go with another tar remover I needed to aggitate the bigger spots. I think it`s way I can`t wash it regualary that is the problem. So it bonds or dry hard on the paint. But the amount of it is crazy. Sonax Spray and Seal has holding up okay. What is impresive with these spray on rinse off products is how well they holds up on the glass. Except from the windshield that is but there is the abrasions from the wipers which it`s not made to stand up to. And a little problems if you only want it on the glass LOL. Another application with Sonax Spray and Seal and planed to use it on the vertical panels. But it`s so easy to use so got on the whole car. So I applyied on the hood after this the Herrenfarth Sprühglanz SPR Limited Edition. And I noticed right away that this was way more concentrated than the other version I have used. Saw the Focus this morning but with the -10C the frost was covering it lol. The surface got a bit slicker and the depth a little deeper and the gloss on par with Sonax. But it`s need to be cured until the gloss pops. And will see how that went when the freezing temperature and a lot of frost covered it over night. That`s a big benefit with the spray on rinse off products as they cure directly when applyied.
Now it`s raining again and is going to be bad weather at least a week forward. So will see if I can get my own car washed and topped up LOL
/ Tony
I like the lights!
Which ones do you like best 60w, 100w, 150w?
Where did you get the L brackets?
Hand washed car for first time since October. Coating still hanging on at 21 months, 36k miles.
Took a bit to uncover it and it`s about near the end but still evident.![]()
Once the nice weather arrives, Zipang-Miyabi-Zipang.What’s next coating?
Have you ever tried Polish Angel UltraRed?Today was the time for my Kia cee`d SW TD to be washed. Some old method and a new method for me to use. The last wash a month ago. It was not as bad as I thought it would be.
This is what I started with. No pre-rinse done this time and it`s not something I useally do either. As I want the prewash to be applyied on as a dry surface as possible. On this picture you can see some tiny gravel. This is what is used inside of the cities and towns and villages where the speed limits is lower. You can also see the water hangs on the side panels.
So I start with applying BBV Degreaser HD. Which is like a tar remover but can also be applyied on a wet surface. If you have tried a tar remover on wet paint most gets like a milky solution. And this was completly free from tar and protected with Carpro Hydro2 lite a month ago. The tar remover I only apply up to just before the windows on the side panels and the back of the car.
Without rinsing the tar remover off. I apply Bilt Hamber Surfex HD at 1:20 from a Kwazar pump sprayer bottle over the whole car. And yes over the tar remover too. This is to desolve the oily road film that gets on the vehicals and other organic grime. Bilt Hamber Surfex HD is a alkaline based degreaser and an APC. Think they claim that the surfactans is polymers.
You have seen the water how it clings on the side panels. This is before picture of how the beading looks on a month old Hydro2 lite before the wash.
The hood after the Bilt Hamber Surfex HD and just PW it off. I use the water pressure from the PW to clean with. So thoroughly go over the panel from bottom and work my way up with the width the PW nozzle tip has. Revived great I think.
This is the side panel after the tar remover and Bilt Hamber Surfex HD and cleaned with the water pressure from the PW. Some beading and sheeting revived. But also noticeble degraded water behavior. Had the Gyeon Wet Coat last winter and feel like it standed up better than Hydro2 lite has done. And Wet Coat now with 50% longer longevity in their new formula for 2019. I think I will go back to Wet Coat or Sonax Spray and Seal. But very interested how Wet Coat is now so think it`s time to order some of that. And they have another brand there that has a lime scale remover car soap which I will get too. Many like that to get a coating more revived with it in combo with tar remover and iron remover when decon wash the coating.
The old method was the tar remover and apply a TFR degreaser directly over it. And the new method maybe gets many to cringe LOL. I bought a Vikan wash brush and it has a water outlet in the brush too. So a wash pole which you can connect to the garden hose and you get flowing water through the brush. I just have an ordinary pole on mine. And an other shape of the wash bucket with a grit guard that fit in it. Used Carpro Reset car soap and the Vikan wash brush and I rinsed it out very often. No pressure where added and just tried to guide it and 2-3 wipe was only needed as a mf wash mitt does and I got a clean paint. I think it worked great and this brush is very soft bristles brush. So what I could notice I did not marring the paint with it. Will see if I continue to use it. Thinking maybe use it on the roof and on the lower parts of the side panels and the rest with wash mitt and wash pads of mf.
Here is my new brush beside a same Vikan wash brush but wider. Would you use the other one on your car LOL? It`s the wash bay where I am that has that and all of the other brushes was in the same condition. I take my own stuff with me and use their PW and water only.
Finished with a new coat of the Hydro2 lite and dried with the leafblower![]()
The wheels was just cleaned with Sonax Wheel Cleaner Plus and PW. The yellowing need a acidic based wheel cleaner to get fully cleaned. So that will be done when it`s time for switch to the summer wheels in about a month.
Thanks for reading if you got through it LOL
/ Tony
Skickat från min SM-T585 via Tapatalk
It`s a pre-wash spray, correct? Thinking maybe something to use as a 1st step when washing/removing winters` grime come Spring cleanup time?I have. Nice product but there`s no substitute for a proper/thorough wash method, in my opinion.
I`d rather spend my (PA) money on many other products, personally.
Sent from my SM-N950U using Tapatalk
Yes.It`s a pre-wash spray, correct? Thinking maybe something to use as a 1st step when washing/removing winters` grime come Spring cleanup time?
Had never noticed/knew about it before, saw a bottle of it today and am curious.
