what are Meg's ultimate products for shine, reflection etc.....?
xenangel-Swirl Free and a polishing pad should remove any marring you got from DACP-normally, if you do not work DACP long enough to completely break it down, you tend to get some surface marring.
So from your experience Scottwax, how long would it take to break down the DACP? I know that i cannot buff dry, but i cant seem to tell if i'm doing it right. Any advice??
And can i use a rotary+Meg`s PlasX on plastic headlamps? I tried doing by hand and manage to remove alot of gunk!! but, is it ok if using a rotary??
about two weeks ago i used a drill + 3 inches soft foam pad(non convoluted....the pad was a flat one) + Meg's plastX at 1200 rpm......used it on the headlights, blinkers of my car as well as girlfriend and dad's car, and there was no prob at all and the results were EXCELLENT :D ......very pleased, and what s more it was effortless.....just my .02 $ ;)
P.S. did as if i was using the rotary.......applied the stuff to the pad, spread it on the surface, then proceeded to buff it off....i moved the drill slowly yet not lingering.
Hope this helps :wavey
lol nope i didnt take any shot of them......i'm sure you guys would like them
;) :D .........those are already quite detailled if you ask me :lol
You can buff it nearly dry and that is how you tell it is time to wipe off the excess....which is another indicator. If the excess doesn't wipe off easily, you didn't work it long enough.
Scottwax~ So if i buff the DACP till it nearly dries, and i didnt work it long enuff, should i mist the buffing pad with water and continue buffing until it dries again?
Or should i just add more DACP on the pad and proceed buffing again
