Eliot Ness
Active member
Yes, but that is an old link and they no longer sell the clay..... I e-mailed them a month or two back to make sure. Plus if you click on the link to order it will never get you to the clay.4AudiQ said:
Bence said:Wooow, a quick reply box!!!
Back to topic; I love the Opticlay as well. It is/was made by K.E.L. aka Kucala Enterprises (Erazer)...
Need I say that we want this clay back??? Someone please enlighten AWC to get off, to let K.E.L. make their excellent elastic clay again.
I don't mind if they market it as Car Doh or packaged as little balls, and they only indicate an alternative use as detailing clay... Who cares? We want Kucala's elastic clay!!!
David Fermani said:I usually do the complete vehicle all at one time so so wouldn't want to clay anything at that time. It wouldn't hurt to clay, but if a customer isn't paying for it(in my case), you wouldn't do it..
SVR said:Well I ain't as good as you buddy. Your the master...Ultra fine at every wash accum - the USA must be a very contaminate filled place.
David Fermani said:I've never used this Opticlay. How does it compare to Clay Magic? Can it be that that much better and how?
4AudiQ said:
Setec Astronomy said:Hey, I notice that the Smart Clay picture in the ACC store looks a lot like the old Opti etc. clays, and they even show it stretched and twisted in an "elastic" manner. Anybody ever use the Smart Clay?
Bence said:David,
It is stretchy, has a more dense, tight structure, yet it is pliable enough. The stretchiness makes the pull-&-refold routine a joy. It doesn't like to stick to the hands as much as CM's clay, and it has another significant advantage: it is more rsistant against the usual soap mixes. As you may have experienced, certain plastic type clays can turn into a disgusting, turd-like substance if you clay-on-the-fly (while washing). The Opti clay becomes just a little bit softer but keeps its effectivity.
Only drawback is the gray color - you can see the contaminants on a lighter colored clay.
DavidB said:It is the old elastic clay made by KEL. The stock is nearly gone (maybe 1,000 units left).
David Fermani said:Someone is always in search of the unatainable product..
EdLancer said:Does it compare to Meg's white Quick Clay ?, its pretty elastic and resistant to soap and lube.
gbackus said:FWIW, the Ford numbered stuff is relabled ABC.
35TH LE said:How can I tell if the Sonus block (grey I assume) is the good stuff? I just bought some from Danase and while it works it is more aggressive then the "medium grade" its advertised as. Pretty hard stuff.... not very elastic and just looking at it it looks grainy.
