indiginous fool
i have always heard that detailing was 10% product 90% how you do it. so i was wondering how you guys do it. i was always taught to but it on in a circle motion.
John Styrnol said:Sealants I usually do back and forth, Waxes circular. Polishes/Glazes circular.
Bill D said:I have alwys done back and forth motions. I suppose if you are concerned about which motion to use, you could always use an inspection light to see if you made any marring from your motion.
JaredPointer said:I can picture Bill now - looking over his finish as he goes with an Uncle Scrooge monacle. Haha!! Just kidding!! :lol
Good advice, as always!!![]()
Except....togwt said:A few thoughts-
Product Directional Application:
•Polish- these products contain abrasives and should be applied in straight-line motions (Forget what Mr. Miyagi was teaching the Karate Kid) circular motions will cause circular directional marks (swirl marks) When an abrasive is applied by hand the pressure applied is uneven and the reflected light highlights the peaks and valleys differently.
•Sealant, Glaze or Wax- these products are all non-abrasive so direction of application won’t cause directional marks to the surface.
•Machine application-although a machine applies product in circular motions the pressure applied is very even (unlike a hand application) so the light is reflected evenly.
•Optimising light refraction (Sal Zaino method) - apply product in ‘direction of airflow’, horizontal surfaces hood to trunk, vertical surfaces front to back. This application technique affects the paints optical properties by optimising the surface light refraction and the reflectivity of the bodylines and contours of the vehicle
