a73elkyss
Still learning
Accumulator said:You can use rubbing alcohol, either straight or mixed 50/50 with water. This will either strip it completely, or at least compromise the LSP enough that the first of the prep steps will be able to remove any that's left.
Sorry, kinda a noob here, but just need a little more clarification. I want to totally strip all of last years Zaino polish off and apply a different version of the Zaino line. I will be claying prior to applying Z-PC, then Z2-Pro w/ZFX.
I previously have used the "Dawn dishwashing liquid" trick to remove the previous years polish. Lately though, I've read different opinions on its effectiveness. So, I'm looking into other possible solutions.
I was considering a mixture of 50% water with 50% Isopropyl Alcohol. I've also read about Meguiar's All Purpose Cleaner Plus (a non-butyl cleaner) diluted 64:1 will remove wax, but this product is being replaced with a butyl based cleaner. The new butyl based cleaner says to dilute 4:1 for dewaxing. I don't know enough about either to know if it is safe for my paint.
I've also read using denatured alcohol. When you say "rubbing alcohol" is that the Isopropyl or the denatured alcohol?
Thanks
