Water Spots on Windows-Your Opinions Needed...
91LSMAN
2002 Chevrolet Corvette
Ok here is the thing. My dad has a 97 Acura RL. He is not the original owner and the previous owner took pretty good care of it, but there have always been water spots on the windows. This morning I washed the car and then I clayed the back window. The glass got smoother to the touch, but the "hard" water spots were still there.
I looked through some older threads and a lot of them said clay, but that didn't work. I'm looking for a solution that can be done by hand.
I also read a thread that said something about steel wool, but I don't feel comfortable taking steel wool anywhere near a car.
Opinions and suggestions are welcome.
Thanks.
Try some poorboy's PP, I used it to take the waterspots off of paint, I'm pretty sure it will be fine on glass. I've read those who use steel wool on their glass are left with micromarring.
Thanks for the response.
As soon as I posted this thread I felt like going outside, so I tried a few things:
1. Vinegar-Didn't work
2. Mother's cleaner wax-didn't work
3. I even felt "dangerous" and tried a little goo-gone.
Forgive my ignorance, but could you elaborate on Poorboy's PP? I'm still kinda new hear and I don't know all of their products.
EDIT: Just noticed you're kinda new here also. LOL
PP (pro polish) is a chemical cleaner, it works for a lot of things, I have used it to remove wax stains from trimming, oxidation very minor swirling and waterspots. Kind of Like AIO w/o protection, and it is liquid in form.
Oh Ok Thanks. I've been kicking around the idea of ordering a few things from them to try out on my car, so I'll keep that in mind.
I have some terrible waterspot that has etched into the windows as the previous owner didn't take good care of them. A few days ago my order for P21S/s100 Multi-Surface Finish Restorer which I intended to use on my grille as there are some waterspot there, it removed them without a snitch. I tried them on the windows, yes it removed them but need some elbow grease as you can imagine we have some hot ass sun all year long baking them into the windows. Since they are all over the windows as well as windscreen, I didn't try to get them all off as I don't intend to use up my tube of Finish restorer just for that.
premiumautocare_1792_2413191
SO I'm going to try out poorboy's pro polish instead (soon,very very soon, poorboy will COMPLETE me:lmfao )
ps: I also used it to clean the exhaust tip coated with black diesel residue which I have been neglected for a year and a half. It came out nicely I must say:)
Btw, don't forget PAC has 10% off when you use the coupon code:naughty .
Alternatively, you could check out motorcitypoorboy , he's got some kickass website
Use Autoglym Car Glass Polish and the glass polishing kit from properautocare.com. It comes with a 3" backing plate for the porter cable DA polisher and some special pads. If you don't have a PC, colkercompany.com has a special chemical for removing water spots. I use this acidic cleaner to remove spots on neglected glass, however, do not use it on the windshield (you can follow this link...http://www.colkercompany.com/glass_restoration.html). Tiny scratches on the surface of the windshield causes by the wiper blades will allow this product to damage the laminate in most windshields causing it to become cloudy. I use the Crystal Clear 550 - Glass Clearing Agent for automotive and commercial window applications. For auto's I would recommend diluting the cleaner with water per the instructions.
Just a note about Autoglym Car Glass Polish, I have this as well, but it does nothing against the waterspot on my windows when using cotton towel, on the other hand it might work with the help of PC:dunno .As for Crystal Clear 550, seems kinda pricy and you have to buy in gallon size, yikes! shame that it couldn't be used on the windscreen, as there's a layer of film I'm trying to remove as well.Cheers for that overtheedge, I'll try PP first, if it doesn't work, I might have to get this
Do update us on what you try out 91LSMAN k;) .
Later
Chee
I will keep you guys updated-just have to decide what to try out.
The Crystal Clear 550 sounded great until I realized I would have to buy so much.
Thanks for the ideas guys-keep em comin!!!!
Later
Chee
$32.50 is really not that bad. Just think about what you have spent on car cleaning products over the years. Also, I need to mention that it is best to apply this produt to a cool surface out of direct sunlight. Shoot, by a gallon, split it up into smaller bottles and sale some to your friends.
The autoglym GP works great with the PC and the special pads. I agree that with a terrycloth alone, it does not help much.
be careful with acid cleaners on glass i messed up some glass last week and im going to find a new way to remove waterspots so ill be following this post . im not proud that i messed up someones glass but ill share good and bad experiences here so you dont do the same thing..i got some bad advice from a pro and it was a learning experience ..
Always be careful with any product that contains acidic cleaners. I have been using this stuff for years and it's very mild and it is intended to be used on glass. Follow the directions and if you are uncomfortable using this sort of product, don't use it. I have not had any problems in the 2 years I have been using it.
I use acid based products all the time on glass without any problems ... here is what I use on the car and on the house windows (yes I do windows)
I go to the local janitor supply store and buy a quart of acid based toilet bowel cleaner
In the shade ...
I put a small amount on a paper towel or small cloth and very carefully wipe it on the windowLet it sit for a few minutes
Wipe off with a wet but not dripping paper towel or cloth.
Wipe again with a dry cloth
Clean the window with whatever you normally use.
This works extremely well, but you must be careful ...
The acid can burn your fingers and it can also damage any metal it might come in contact with.
Someone mentioned in an earlier thread that he used an acid based wheel cleaner.
If in doubt always try a small are first.
im dead serious...i have seen it in some truck mag and i have seen on some websites where they say it works...
no dude i would never trick someone into doing something like that to their truck with a chance of damaging or hard to get off lol
Tothpaste is a mild abrasive (polish).
It works good for a lot of things like polishing light scratches out of plastic.
I haven't tried it on water spots yet but why not?
