imported_jaobrien6
David,
I just noticed the warnings you have listed on the SFX-1 and SFX-2 pads. So these would be more aggressive pads than, say, the orange and green DAS pads? Based on the OPM limits you have listed, it sounds like you recommend very low speeds. For example, the SFX-1 pad you have a recommended limit of 3000 OPM. Since the PC goes from 2500 to 6000, I'm guessing that keeping it under 3000 means you shouldn't go above 1 or maybe 2. Is that what you're recommending? Have you actually seen damage cause by these pads on a PC (or equivalent) at higher speeds?
I have my SFX test kit on the way, and was hoping to get a little more information about this before trying everything out.
John
John
