Want ot buy a polisher
B@tm@n
Hi there you guys. Am new to all this machine stuff and want to buy one. Was going to get a PC when I was in the states, but couldnt find one. What would you recommend that is similar to the pc
G110 in the states or G220 overseas.
If Iceland is 220 volts it might have been a good thing you didn't find that PC or you would have had to get a hefty transformer to run it.
Like REVNU suggested the Meguiar's G220 is most likely the best entry level polisher for a beginner.
B@tm@n said:
Is it as good as the PC or should I go for the flex or the Makita?
The G110/220 actually has a little more power than a PC. If you can afford a Flex 3401 that might be an ideal choice for you, depending on how much correction you plan on doing.
There are a lot of threads here about the Flex so you should be able to get a pretty good idea about it. Just remember they also make a rotary so the model 3401 DA is what you're looking for. Also remember you want to try and get a 220 volt version to avoid needing a transformer.
