Jngrbrdman
See, mine got displaced a bit, but it stayed in the housing. I stopped it as it started to pull it loose, so that may be the only difference between our machines at this point. My backing plate is just as grooved as yours is.
See, you've got the same problem I've got. That felt piece is supposed to be attached to the machine itself. You'll notice a spot in the housing where it goes. That track melted into the backing plate is not a good sign though. That is the same thing mine did, only it didn't pull the felt out.
I just called Powerhouse Distribution and explained the problem. They said this is pretty common. One of the reasons for it is that Flex sends the tools without lubricating that felt strip in there. They have started adding some oil to that before sending them out and that seems to be solving the problem. All they need is the serial number and date code off your machine and they put in a warranty claim and send out a new backing plate. That is what I'm doing as soon as I get home and we'll see how it works. I've heard they send a new backing plate and felt ring as well. Hopefully this sorts out the problem. 1-888-809-4749 and I spoke with Ben. They seem to be pretty familiar with the problem and they didn't give me any greif about needing a replacement.
They are the US distributors of the Flex tools, so they are the ones to contact when there is a warranty claim. I bought it from somewhere totally seperate, but since they are the entry point, they are the ones to contact when things go wrong.
So, would you suggest going ahead and getting one? That is, of course, if someone is on the edge looking to get one? Does this seem like a minor problem?
I think the Edge adapter is going to solve a lot of problems. The reason for this happening on the units that I've seen it is unequal pressure on the edge of the backing plate causing it to rub. The Edge 2000 system would mount in the center and be connected directly to the gear. There would be no pressure on the edges to worry about. This kind of thing wouldn't happen with that system. It doesn't happen on all of the Flex units out there either, so it is probably just luck of the draw. Autogeek wouldn't sell them like hotcakes if there were some major defect to them.
Did someone say bullet? My kind of people, I must be in the right place.I bit the bullet this past weekend and ordered a Flex from Autogeek. Hopefully the Edge adapter will be on sale by this summer; in the meanwhile I still have the PC to fall back on for minor jobs.
