Alfisti said:Part A of NS needs to bond to bare paint. It's recommended to remove any underlying product with IPA, or similar, for best results.
mystickid said:Thanks Alfisti, could you guys point me to information on how to properly store and re-use this product without diminishing quality
brownbob06 said:Rub on part A, rub part B over part A. Let dwell, buff off.
Not very complicated application. However I would like to know how to store properly as well.
bert31 said:Based upon this, a user of Nitro Seal would not want to use a paint cleaner or AIO before Part A I assume. I ask because after polishing I often like to use a paint cleaner or all in one to clean the surface before applying a wax or sealant. I guess if I wanted to do that, I would have to clean off the base left by the AIO or paint cleaner with an APC wash or ISA wipe down. Would that be correct?
morne90 said:Part A being the Aminofunctional liquid forgather and the Object B is a crossbreed Montan wax flower. When these compounds are mixed unitedly, the paraffin merge (Try A) gift oppose with the wax gather (Start B) to descriptor a covalent trammels so that the resulting arm instrument heal into a hard cross-linked plaster.
Woody Wax said:The storing of the product does not have to be complicated, simply make sure the caps are tight, place in an air tight bag (i.e. ZipLoc) place in a cool storage cupboard or fridge (next to the Jack Daniels works best for me)
I would suggest not using an AIO if you can avoid it, by reasoning if the base is less durable than the top coat it can diminish the longevity of the product.
IPA is a good option; alternatively if you’re using HD UNO or Polish then HD Nitro is compatible with both of these and will bond perfectly fine.
Cheers Daniel
TOGWT said:There are a few people on this forum that have more than a 101 Chem backround; this is vendor science fiction (non PC = total BS)
Barry Theal said:... Rub-in to the whole section of the vehicle massaging in over and over. ( section could be hood fender or door...etc). Do not buff-it yet.
To another applicator apply few drops of Part B and rub-in to the same section. You will see that Part A is not properly dried and has some patches of mat sections. No problem... Just go over it and massage in the Part B.
While letting this section dry and move to the next sections until the entire car is finished.
Come back and now buff in to a brilliant shine with Microfiber towel or a very soft cloth.
