Undercarriage
After removing dirt, road grime, and etc neutralise the effects of the acidic road salt on the suspension / undercarriage (See also Salt and Road salt)
Methodology
? Thoroughly spray an undiluted citrus cleaner (P2IS Total Auto Wash) and let it soak in; remove by thoroughly rinsing with water. If you have a pressure washer available, fill tank with citrus cleaner and spray undercarriage (do not use excess pressure as water may penetrate crevices and seams where it cannot drain, causing corrosion), let it soak and then remove with plain water
? Spray undercarriage with (Chemical Guys Bare Bones ) one application will leave no residues, noxious fumes or flammable solvents
? Or apply POR-15 Marine Clean? and then two coats of a rust inhibitor paint (POR-15 ) allow each coat to dry
Alternative product - Wurth High Build Underbody Spray produces a jet black, textured finish in wheel wells and on lower rocker panels. This spray will hide a multitude of blemishes and make old wheel wells look factory new. Provides permanent yet flexible protection against flying stones, rust, water and road salts
Wurth SKS Stone Guard matches OEM Factory applied stone protection on vehicles such as BMW, Fiat, Mercedes-Benz, Porsche and Renault. For use on door sills, front and rear body parts, mudguards, under bodies, rocker panels, etc. Wurth SKS Stone Guard is a water based product and offers easy clean-up. Wurth SKS is paintable and can be top coated with solvent based urethane or water-borne top coats (available in Black or Grey)
An extract from ?Automotive Detailing, Inside & Out?, a knowledge base for the perfectionist ? TOGWT ? Ltd Copyright 2002-2009, all rights reserved.
This book enables direct access to five decades of detailing knowledge and experience
Please remember no link to other companies products, just post where you got it.....ex ( Sam Wax Shop )
