I have been having trouble getting responses from the membership. I hope my initiation is over b/c I could use some advice and help getting rid of micro marring on my black M35X. In the shade it look great, in the SUN, looks like thin strands of spider webs are on the car and catch the light.
I am using Ultima products top to bottom. Can someone who has sucessfully used this (Ultima) line please give me your opinions on the following products
mine are listed below)
Tire and Trim
Paint Prep
Ultima Paint Guard Sealant
Elastrofoam Block and Lube
Ultima QD
Interior Gel Shampoo
Interior Sealant
Here is my experience. My backgroung prior to Ultima has been with Colonite 845IW and Grey (fine clay)Mothers car wash, and P21S Gold W/C, and Trutle Wax Bug and Tar Remover, Stoners GC Trigger. Main reason for a switch was WOWA sealant, figured the less I touch black the better!
I am very Happy with the Ultima system although it has only been on the car 4-6 weeks so durability is still yet to be seen. Some minor issues I will detail each product below.
Tire and Trim-Easy on, great coverage, lasts and lasts! matte to low gloss finish 8.5/10
Paint Prep-Used by hand clears up light micro marring. Using PC (and orange pad) I made a mess-could be me, it was my first time and am waiting for a new pad from Manufacturer. 8/10 by hand Unrated by machine until I figure it out! If you have had good experience please share procedure. I am not sure if i worked polish to much, or too liitle or used too much or too little!
Ultima Paint Guard Plus Sealant-Super easy on, WOWA, Great beading after 4-6 weeks and nice slick feel, nothing seems to stick (dirt, Bird bombs and bugs). Only issue is in some areas I need to QD to get application streaks out. Seems I had been over applying. These are only seen on dark cars and usually where I start after reapplying product to the applicator. Stuff should be used micro thin!
Elastrofoam Block and Lube-I was told my applicator was bad and it is being replaced. Came in white and chalky. Will rate later.
Quick Detailer-Awsome product. Smells great, works like magic. Creates great depth, gloss and wet shine. Adds Slickness. 10/10
Ultima Car Wash-Good Suds, Smells good. My car has never been really dirty so its fine. Fast rinsing, no film left behind and suds last all wash. Also use as wheel cleaner 1 oz per gallon applied in pump sprayer.
Interior Shampoo-Again car is new so it cleans, smells OK.
Interior Sealant-Did 1/2 of dash and it is evident that the sealed portion is slightly darker black and all dust is easily removed with a damp MF towel. Did dash, wood trim and plastic in door jam and Steel jam plates. 9/10
If I could solve my micro marring issue with the PC and Paint Prep I would be golden!
Anyone on Long Island, NY using this system on a black sucessfully?
Thanks,
Jeff
Tire and Trim
Paint Prep
Ultima QD
Interior Sealant
Thanks,
Jeff
