William_Wallace
I don’t prefoam but I do soak a vehicle in APC or degreaser then blast car with pressure washer or hose to knock dirt off. Depending on how motivated I am to drag out my pressure washer.
I don`t know about "very large" but from the sound of it you`d want a subpanel for this area. If you have electric heaters you`d probably want to run them on the higher voltage you have, probably 230 or 277 if it`s a newer building, rather than 120. You might want to look into a gas space heater if you`ve got natural gas at this location. I`m expecting Accumulator to chime in also on this electrical stuff.
Propane is fine, when I said "if you`ve got natural gas at this location" I almost added something about propane. Usually gas (propane or natural) is considered a more efficient way to heat, of course going forward I guess a lot of this stuff may be going electric, so maybe your original plan is just as valid.
Thank you for the reply! The reason I`m asking is because I`m actually going to build one about 8 months from now. And I`m not opposed to spending the necessary money to build a really nice one. For me, "nice" just means super convenient. Real easy to do a good wash job with minimal time spent doing it. And hopefully minimal mess. So I`d like to see all this in some form of a picture, to hand over to the builder. I can have someone make the picture/plans, but I`ll need a list to give them. So from your post, the list would look something like:
1. Floor drain (with oil separator)
2. Water and air hoses on both sides. Coming from the ceiling for convenience
3. Ten 70 amp outlets on each side (having extra is good here)
4. Florescent and point source lighting (point source means pole mounted lights I can move around?)
5. Nonslip flooring
6. Size... but how big? Maybe 30`x36` would be ideal? Or 40x40? I wonder how much space you really need if you`re gonna have the curtain.
7. A huge shower curtain. (I love this idea. It just sort of closes around the car when you`re spraying stuff... correct?)
8. Plenty of shelving along the walls for storage
9. Heated power washer on a swing arm?
10. Water heater (for power washer I assume?)
11. Washer/dryer
12. Buckets and shelving on both sides for all wash equipment like more buckets and towels, soap, etc
13. Jacks and jackstands (yeah i prefer those too as opposed to lifts)
14. HVAC - (will already have for the workshop area but this car wash may be a different room)
15. Anything else anyone would add? To make the washes go as quickly as possible?
Well I`m in Texas and I`m kind of hesitant to run the heater off natural gas. I think I`m just going to do a giant propane tank instead. Natural gas was the reason we had a power outage for 3 days. Seems like we`re liable to run out of gas again at some point, so from now on I`m just going to rely on having power on hand.
Propane vs Gas kinda sounds like it makes no difference, but I like to mention these things just in case it does. It never fails someone always knows something I didn`t![]()
Ok well I think that answers my question for the most part, but it does raise another one for me:
Is there any real way to wash a car that doesn`t scratch the paint? It seems like a power washer is going to push some dirt particles into the clear coat before it blasts them off the car. And of course we all know that wiping a car just rubs dirt into the finish. These both clean the car, but they do some measure of damage to the clear coat.
Is there any way this can be avoided? Seems like the answer is no, but I just thought I`d ask.
I`d give thought to what walls/finishes will hold up given the application. Painted block works for me, no way I`d bother tiling it (that`s how I did the bathroom).So if you have any ideas that you think would make it look awesomer, I`d love to hear them! (I`m thinking about white subway tiles for walls in the wash bay)
..although if it`s that big, perhaps this giant shower curtain idea isn`t really necessary. Although I`d still like to do the curtain just for fun. Maybe just use a larger curtain track.
So one for washing towels, one for drying towels, one for dirty towels.. any other bins?
I guess the only things you might have around that you`d want keep from getting wet are: Product, your towels, your detailing extractor, any other tools or shelving that might be around. I`m trying to get the design all set up in my mind for how to arrange this thing.
Heh heh, you`re making me wish I had that curtain!I`m thinking the main thing is the curtain, cause you could just have everything else on the outside of the curtain. When you`re done washing, simply move the curtain. Now you can detail the rest of the car.
I`m hoping for find a good electric power washer, that also works with a long swing arm. The less I deal with cables and hoses, the better. Currently all my air hoses and extension cords come out of the ceiling and roll back up there when I`m done. Huge time saver. I would like to continue that trend. How many PSI is your current power washer? I want to make sure I have plenty of pressure for washing cars, but not so much that I risk damaging the paint.
I have propane in my work garage. For some reason it doesn`t feel warm like oil heat.
Not being a builder or architect, nor am I familiar with the area of Texas that you live in, it would be difficult to access your list for its vehicle detailing correctness.
1) What are are zoning laws and building codes for your area where you live? Building out in the middle of nowhere or largely rural area is MUCH different than a zoned residential area or a private estate community that may have covenant requirements as to what you can or can build.
THAT assessment would be my first and most criteria for my detailing garage. That may dictate: ...
Amigo -
You are in Texas where all the Fracking is going on, and you have a natural gas shortage???
How is this possible?
And a power failure for 3 days because of natural gas???
Huh???
Regarding Electrical -- ...
I`ve found that the smallest/weakest/cheapest pressure washer if fine for washing vehicles, no matter how dirty they get. I`ve had much more powerful ones, but don`t miss `em a bit for this application. So IME you can do fine *for washing vehicles* with the lowest psi/gpm units available.
Don`t be quite so quick to call yourself "wrong"Guess I was wrong about this, but I always thought you wanted the most pressure and water volume you could get without harming the paint. Within reason of course, but it would still come out to be a pretty nice power washer. And as usual, expensive. But the idea was to have the power washer do the work so you spent less time wiping.
There must be some kind of limit I`m not aware of. Maybe there`s some pressure number where you won`t take the paint off, but you`re still hurting the finish.
What do yall think about heated power washers? As a teen I worked at a light pole plant, and we had to degrease all those giant light poles you see in parking lots before they could be painted and sent out. We had an awesome heated power washer there, it was heated by propane. Those poles came from china caked in gunk and it was all coming off once that power washer got warmed up. It was scalding hot.
Any thoughts on using something like that on a car? Sounds like a bad idea to me, but I`ve noticed some people have been "steaming" their car paint lately lol
Are not heated pressure washers called "Steam Cleaners"?
No, those are different. The hot-water pressure washers don`t get *that* hot.
The heated ones are awfully pricey, and I myself would never have a Detailing-related use for them. (Of course a situation like Stokdgs`s father had would be different! We used a big propane-powered steamer for that kind of thing.)
FWIW, and this might be ill-advised, so don`t just assume it`s OK....I`ve run hot water ("water heater turned up pretty high"-level) through mine a few times without any issues, but found it simply wasn`t necessary as "regular quiet warm" water (water heater on "regular HOT", both hot and cold water turned on FULL) worked fine even on the winter salt/etc.
