Twin-Turbo Lamborghini LP560 + Twin Turbo Ford GT by autoLavish
MarcHarris
No folks, you're not seeing double: 2 Super-cars, 2 sets of 2 turbos, 2,000hp, and the autoLavish duo made this a fun experience.
Normally, we don't post anything that doesn't have correction performed, but with two amazing cars, we figured it'd make a cool thread. We were originally contacted by the 2006 Ford GT owner to give his vehicle some much needed attention, and trust us, this thing needed every single thing we gave it... and then some. The car often hits the track, and the owner has it at events all over the nation, most recently a charity event put on by the Utah Highway Patrol. The owner is very active in the GT owners circle, and makes a point to drive his car as much as possible. I believe it has nearly 20k miles on it for this exact reason.
To begin...
Cleaning began with interior work first. Jacob began vacuuming, while I attended to the nasty door jams. Afterward, Jacob handled the filthy floor mats while I hit all hard surfaces with 1Z Cockpit premium
Moving away from the interior mess that was now looking much better, we got started with the exterior at the wheels. P21S wheel cleaner gel handled this job with some agitation.
Chemical Guy's Citrus Wash & Clear helped prep the car for washing
Following washing, claying was performed. As some many know: claying a white car is longer than any other color. Claying a white car that has seen a bunch of 200mph runs is even worse: it's brutal. Trust us. Even afterwards, the lowers and intakes intended to cool the brakes weren't perfect. We had a budget to work within.
After being rinsed free of clay lube, we started applying protection. Danase Wet Glaze was used via PC to give a high amount of initial slickness while muting paint defects. It also proved to work quite well on water spots that littered the racing stripes.
Allowing the DWG to cure, Jacob applied Meguiar's Trim Detailer spray was used on all black trim, and I got to try out a new product myself: Danase Diamond Gel. The directions state it can be used on trim and plastic, but I decided to give it a try on tires first. This product is as thick as honey, and likely would be best applied using a foam applicator. It spreads decently thin for having such a thick consistency, but best of all: it hardens as it dries. Once completely set, it's almost like a shell of protection that is completely dry to the touch despite the slightly shiny look it gives. To give a more matte finish, simply wipe before it completely dries. I can't see myself using it on rubber trim, but plastic bumpers, tires, and plastic trim would be the best candidates in my eyes for future use due to ease of use on those larger areas plus outstanding protection abilities.
Other areas also got touched up to cut down on eye-sores as much as possible in the time we were allotted
Following the DWG up with a coat of Danase Sealant (If you like DWG - you're sleeping on this product. I can't believe I waited so long to get some), the GT got a final wipe-down with FK 425. At the same time, all glass was hit with Meguiar's Glass Cleaner Concentrate diluted properly with pure (0.00ppm) water.
Irony as expressed by cars
The end result of the clayed, DWGed, Sealed, and QDed paint was an insane amount of gloss for not having correction performed.
Everything said and done, the car looked 100% better in minimal time.
The Heffner Performance Twin-Turbo kit giving this baby over 1k hp (900ish at the wheels) surely doesn't hurt its sex appeal
Next up was a quickie but goodie. The owner was looking after Heffner Performance's newest creation: the LP560 Twin-turbo and wanted the exterior cleaned up as quick as possible. The vehicle was up here to be tested by a certain Michigan-based auto magazine, and was soon to leave to head out West for more testing by more publications. Everything on the car was pretty much stock outside of the twin turbo's and a tune which give it over 800whp. Not bad for AWD eh? I can't describe the sound of this baby, but you can imagine it's quite intense.
P21S Wheel Cleaner Gel was applied, agitated, then rinsed to a clean finish
Next was bath time
Following a rinse and blow-dry, Meguiar's Trim Detailer was applied to all vents, and Dodo Juice Red Mist Tropical was applied to all painted surfaces to provide slickness and limited protection while maximizing shine for the time spent.
Hope you enjoyed the eye candy! Next post will either be a lifted blacked-out Jeep, or our full Concours d'Elegance treatment of a 1929 Ford roadster :)
I had a feeling the mutha load of the Detroit detailing duo was going to drop like an atomic bomb. Way to represent the D boys!!!!!!!
wow! You just made me not want to go to work LoL. THose are som awesome cars right there! Excellent work guys!
BTW what kind of pressure washer setup and foam lance are you guys running?
Spekt for the score, spekt for the work and even more spekt for paying attention to your grammar so well :)! Don't see that much these days!
Thats more HP than the last 5 cars I have detailed combined.
Lucky bastaads! Really excellent finish on both grannymobiles!
Thanks Dave - and this is only the tip of the iceberg ;)
Cholleman said:
nice work. no engine pics? :sadpace:
Sorry!
Thank you, and the pressure washer is made by Black&Decker with a foam cannon using a Bosch fitting
MotorCity said:
Nice!!
Is this Royal oak?
Thanks Jasos, and yes in deed it is
Lol Jesse - I don't even know what a "spekt" is! Thanks bro
Ay bro - we can't let you hog ALL the nice cars. You Cali boys have more than your fair share anyways :P
ramtough said:
Now their is some nice shiny cars. They both look good in foam.:2thumbs:
We appreciate it
wow white never looked so good! looks like you guys are having some fun these days. keep it going. Success comes real fast! enjoy the ride!
tdekany said:
Awesome results!!!!
thanks, they both cleaned nicely for limited work
Thanks a lot Barry, we're surely enjoying ourselves and have had some really awesome cars/clients lately. Surely more to come
TSC17 said:
Beautiful work fellas! It looks like business is going well...congrats on your success my friend.
Thank you Todd. We're no TSC17, but we're trying to get there! Seems like you've had some awesome adventures lately. We're hoping to continue this wave as far as it'll take us
You titled pic 14 as "Irony expressed by cars".. the Prius with the GT and the Lambo.
Yesterday afternoon, on the way back to the firehouse after a call, I saw a new Honda Insight with a Massachusetts vanity license plate that spelled out...
Ford GT
Great work on 2 great cars!
Ford GT
lol... what are the chances of that?
d00t said:
Marc, what an amazing job! You deserve these high end cars!
Thanks Aaron, hope all is well with you buddy!
I dearly do love white cars, especially these two. But then I am a little biased. [see avatar] :) Well done!
