MarcHarris
Despite being over 6 years old, the styling of the Lamborghini Gallardo still has a commanding presence on the road. Smaller, lighter, and arguably more driver friendly than the Murcielago, the Gallardo isn't only well built for an exotic (something you wouldn't say of many past Lamborghinis), it has some amazing potential if an owner is daring enough to tap into it. This Gallrdo is one such example.
We gave the estimate for this car to the owner 10 months prior to working on it. After he saw the end result (not even full correction - the goal here was presale prep), he made it known the replacement would be getting the AutoLavish treatment at the beginning of his ownership rather than towards the end. Though the PPG Cerami-clear shell has been holding up well, it was still plaqued with light swirls, excessive marring, and other problems due to improper washing techniques which overall led to a big lack of clarity. Lack of clarity and cleanness is the number one issue in a vehicle looking older than it should. The scratches, swirls, marring, and other visual impairments refract incoming light so that the color doesn't shine true to the eye. Fixing such issues allows for proper reflection of light resulting in a more vibrant appearance that looks crisp and sharp: these are the exact type of things that truly add to resale value of a car.
With Jacob suffering from badly strained back muscles (happened when we had three cars in three days which started with a 13 hour marathon on a turbo NSX), I was lucky enough to have a good friend of mine able to lend me a hand. Nate is not only a car enthusiast, but a motorcycle mechanic with a good grasp of how things work. It also helps he's dabbed into detailing a little which allowed me to be able to assign him tasks of what to use, how to use it, what to look for, and why, and he could get it done. Putting your reputation on the line as a person and business is not a light decision, so I'm glad I had someone trustworthy to lend a hand.
Upon arrival, the "pre washed" Gallardo was waiting for us.
The owner was most concerned with making the engine bay look as nice as possible. After a custom twin-turbo install, you need to be able to show off the goods. The light build up needed to be safely removed to bring back the looks.
Intake not looking as shiny as it should...
Nor did the exhaust tips.
Standard build up in the gas cap area. Nothing too bad, but in need of some light help.
Door jams rarely are cared for with most cars - here you can see the dirt that has settled.
I began on the engine bay with a boar's hair brush and P21S Total Auto Wash to help loosen all grime. While TAW might be on the expensive side, there is little I'd trust more on an expensive customized engine bay. It is not only safe - but effective.
Nate began with treating each wheel to a nice layer of P21S Wheel Cleaner Gel. The beautiful aftermarket wheels could have easily been damaged with the wrong type of cleaner, so P21S got the call to action. Not only the wheel faces and lugs, but inside of the wheel, the brake calipers, and behind the spokes were all treated. Here the calipers are cared for with a 1inch boar's hair brush
