occupant
Occupant Ilied Industries
I FINALLY got around to doing the headlights on the Durango. After driving to/from Hillsboro at night and not being able to see anything other than fifty feet of road in front of me, I had to do something. Couldn't afford new capsules ($150/pair aftermarket or $250+ OEM). Still don't own a buffer of any kind and my cordless drill is pretty useless after a minute. Decided to try this out one morning when the toddler was sleeping in.
I paid $8.47 for this kit at a Wal-Mart store in Hillsboro, TX. You get what you see here plus a clear foodservice-type glove (one only, not a pair) for the little packet with a towelette sealer thing in it.
From left to right:
box with instructions in English and Spanish
bottle of spray lubricant for sanding pads (clear liquid)
bottle of lens clarifying compound (white lightweight paste)
packet with lens sealing towelette wipe
sanding pads (green is #1, brown is #2, purple side of third is #3, blue side is #4)
I started out with this, driver side:
I washed the couple of bugs off the light and followed the first of the instructions, which was to try and use the lens clarifying compound only with a terry cloth towel. Results, not very much of a difference:
So I brought out the rest of the kit and got started. Instructions said to spray the lubricant on and then scrub in one direction (I started horizontally) with the green #1 pad. After a few minutes, it said to immediately switch to the brown #2 pad and scrub in the other direction (vertically for me) and add lubricant as needed for a few minutes. After doing that, I had this:
Still didn't seem like much of a difference in clarity but I was still only done with the two roughest grits of sanding pads and all the yellowing was GONE. Next up was to rinse clean, apply lubricant, and use the purple #3 side of the third sanding pad, then rinse clean again, apply lubricant, and use the blue #4 side of the third sanding pad. After all that, I had this:
I can see the curvature of the reflector now. This is looking very promising! So the final steps are to use the lens clarifying compound with a terry cloth, then buff with the terry cloth, let dry, and apply the lens sealant with the glove on and let it cure for 24 hours. After the compound and buff, here's the result before applying sealant:
This was all done yesterday, and I just took a picture of the headlight after the sealant had 24 hours to cure. Not like it looks any different, I'm just darn proud that these headlights are good to go. Night driving is, literally, a night and day difference. There's PLENTY of life left in the kit to do it a dozen more times, but I might need to buy more sandpaper and I won't have the sealant again (one time use). That's when I break out the bottle of NuFinish in the trunk of my Torino and give it a coat every 6 months when I re-do the headlights. *IF* they need redone. So here's the ten-minute old pic of the light as it looks RIGHT NOW while I type:
I did the same on the passenger side headlight and I probably need to do it over because I got distracted when my daughter woke up and started tapping on the window to ask "why daddy outside NO FAIR". I didn't bother taking pictures either but it was as nasty and it is now almost as clean but there's some deeper scratches and I should have taken more time with #1 and #2 sanding pads, which I am GUESSING are 800 and 1000 grit (the purple is probably 1500 and the blue 2000, going by feel versus real sandpaper I have felt in the past, it's a wild guess, but oh well)
For $8.47, this gives the average Joe almost all he needs to get r done. A water supply for rinsing, a terry cloth (I actually used a clean crew sock, turned inside out, no joke) and a soft cloth (I used a couple of dried out baby wipes that were laying in the glovebox of the Torino, ain't I cheap?) were all I had to supply. I am impressed with the size of the lube/compound bottles and the sanding pads were kinda small but I was able to use them without complaint. Total time including two cigarette breaks, stopping to sign for a package from UPS, interruptions from my daughter, and talking to our babysitter was 1 hour 10 minutes for both lights. Could have done it all in 20-30 minutes if I was in a hurry and had no one to bother me. If I ever see these on clearance I'm buying them out.
From left to right:
