Took off too much clear coat.
joshtpa said:
I am pretty sure that if I took 360 sand paper and rubbed my car for 45 seconds (that is a fairly long time), it would go through the clear coat.
You could go through with 3000 grit in less than 45 seconds of sanding the same spot.
that is exactly what I am saying...I was disputing the fact that Junebug said it could not be done with sandpaper.
are you sure you went thru the clearcoat and it just isn't hazing? 3m will haze by hand. If it is hazing use a mild polish like Mothers Powerpolish to remove the hazing.
exactly what i was thinking...wondering if thats what its suppose to look like after a heavy compound....
now, :secret , go get some lighter compound, heavy polish, then light polish, than wax....should look great !!
join the club...we have jackets!
Thanks for all the advice. I will try some of these ideas. I buffed it with some light polish, no luck on getting it out either, so I waxed it. To the guy who was wondering why I did the rest of my hood lightly, the oxidization had come off in the area I was polishing leaving a brighter area of streaks. I just wanted to a: see if my dark spot would match the rest after a brief polish (no, the rest of the hood got lighter, duh) and b: I wanted the oxidization streaks out. I figured 5 seconds of polishing couldn't damage my car further.
Ok, I am using the improper term then. What makes my paint lighter (silver car) after you lightly polish the surface (E.G. nufinish scratch remover, or this 3m crap). Whatever that is is what I am talking about.
nich0lai- The paint probably looks lighter because you're polishing away all the contamination/etc. that's between the paint and your eye and also removing marring (which will make the light refract instead of reflect).
As for the damaged spot, if the original issue had thinned the clear then even "normally OK" polishing could have compromised what was left and led to damage. I've done stuff like that before and, well... [stuff] happens. Short of using an electronic thickness gauge every time you polish I dunno if you can avoid having an "oops" every now and then. Think of it as a lesson in living with imperfections as opposed to striving for literal perfection. But I *will* say that I woulda been mighty surprised if that happened to me, at least on anything other than my Mazda MPV (crappy build-quality/paint/etc.).
On the off-chance that it *is* just hazing, you could try further polishing with milder/better finishing products. If you do *not* luck out you'll make it a bit worse, but in that case you're looking at paintwork anyhow so I don't see any real downside to giving it a try.
Oh, and I'll offer a little gentle advice to consider getting some different products that will perform the way you want them to. If I read you right, you're considering the Nu-Finish polish to be better than the 3M product and that's, uhm, surprising. FWIW I always recommend 1z brand polishes for people who are just starting out (good for experts too ;) ) in part because they're *very* user-friendly while also being effective. Sources for 1Z: Welcome to Exceldetail.com! or Aloha & Welcome to Our Oasis for All Your Auto Detailing Supplies & Accessories
THANK YOU!!!!!!
That was exactly what I was looking for. Thank you, thank you, thank you. A truly enlightened individual among car polishers.
