Jean-Claude
Keeper of the beautiful
jlb85 said:The achiles heel of coatings, and clear coat per se, is that to repair the damage from bird crap (as an example) requires significant effort and work in most cases. A wax can be removed and replaced quickly, as can sealants, albeit they are much weaker to the damage. The articles touch on this a little, but we had to keep them short, hoping the reader would figure this out.
Regarding heat, and this is the engineer in me, "heat resistance" means nothing of value to the detailer, and is used as a blanket statement in attempt to qualify a product over another. What does heat resitance mean? Does it mean the coating is still there after a heat cycle? Or does it include that the coating is still effective after a heat cycle? Is it just as effective or did it loose some of its qualities? How many heat cycles can it withstand before a decrease in "protection" (another empty misnomer technically)? What temperature do the cycles have to be before it decreases performance? Does the coating's bonding to the substrate suffer during a heat cycle?
I had a client (non automotive) that fire kilned C1 to 1000 degrees F. After one firing it was "still there", but not after a second firing. Further, he mentioned after looking at it under a microscope (I assume), it didn't look like it would be very useful after that firing. With an exhaust going upwards of 1000 degrees F air flow (my boosted EGTs run 1300-1500 F, and although not all of that gets to the surface, most of it will), how many cycles would a coating protect against? Would it delaminate? Will it still prevent blueing? On a Harley the exhaust temps are MUCH lower (straight low restruction pipes in an underpowered combustion cycle), but how about brake calipers? Those can see enough temp to fry powder coating after a few cycles, and brakes get over 1500 F on even a street car. One track day and I can assure you the calipers have melted away any protection.
So heat resistance on paint is something I will sell to my clients. Saying a coating will protect their calipers or exhaust is something I would be very hessitant to mention, although I know some clients will never cycle their brakes that high, which are the same clients that, like Charles says, never wash their own cars and are the ones who could benefit the least from a coating, other than it being "expensive and the ultimate in protection", which it is.
The extremely appealing glass look of a coating comes with caveats, which need to be understood by the professional and the client.
Most of the cars I work on are not track cars. My client's track cars have the crap beat out of them and they don't care about them as much.
But if I am removing the wheels so they can be thoroughly detailed and coated, it makes sense to coat their calipers, imo. They are paying for the wheels, not the calipers. So there is no skin off their backs. In the case that they aren't threshold braking and super heating their calipers, it will probably stay right where it is and make maintenance easier.
None of this is to prove what you're saying is wrong as I agree with it. But no one can speak absolutely about coating calipers/tail pipes and its usefulness. It should be a case-by-case consideration.
