Wow, thanks guys! I've never been a part of a forum that has responded so quick. I'm def gonna pick up some 845 for the wife and I. I'm excited, I get my first customer next week!
You'll love 845, but it can be finicky to use.
I have talked with Patrick from Collinite and he gave me a few tips, and I have since found a few methods for success as well.
- Shake it up! It will liquify into a melted butter consistancy. This helps with the next point.
- Thinner is better. I put 845 in a spray bottle [and now other companies have started selling it with a spray head] as it is a really easy way of applying thin. I spray [mist] a MF applicator and I can cover an entire panel with just a mist. Put it on thin enough that you are wondering if you are even applying it. If you find the 845 to almost flash when applying, it is going on thin enough.
- Do not let it dry. When it hazes, you can remove it. Problem with applying it too thick, is the difficulty of buffing it off in its entirety. If you let it dry, it will be as hard as a rock. Wax 2 panels, and go back and buff the first, apply to a new one, then remove from the second panel, apply to another, repeat.
- On your personal vehicles, if you wish to apply another coat, you may. After letting it sit for a week, you can reapply with "light" pressure and buff it off again with light pressure. 845 has some solvents, but with a delicate additional application, you can add to the longevity.
- Accumulator, a member on the other site, has found applying 845, then applying 476, to create a very protective layer of wax. Again, after waiting until your next wash, he applies another coat of 845. It creates an impressive combination for the paint.
- You can use it on plastics, but make sure you test a small spot first. Apply the wax, and buff it in like you are cleaning the plastic. Then, buff it off. Don't let it dry on the plastic, but apply and remove right after.
I don't think there is anything else too imperative to know. Again, shake it up, apply thin, remove at the right time, and enjoy!
