the dawn method, pros and cons
Scottwax said:
Agreed. I also carry a spray bottle that is 50/50 water and alcohol to do the same if necessary.
Alcohol is safe on trim?
Since you use it, I assume so. Do you really need to soak the surface or is a light mist followed up with a microfiber towel enough to remove grime, old wax/sealant, etc?
If I am washing using water/alcohol, it doesn't seem to bother trim, when spraying it on the paint and letting it dwell, I try to stay away from trim just to be safe.
Scottwax said:
If I am washing using water/alcohol, it doesn't seem to bother trim,.
When you wash with water/alcohol do you mix it with ONR or your wash bucket consists of only 50% water/ 50% alcohol no car wash/ONR in the bucket?
When washing with water/alcohol, are you using it to remove the previous LSP or because there is something on the surface that wash alone will not remove?
Is only a mist required or do you saturate the surface?
