Todd@RUPES
Just a regular guy
Once upon a time, sanding your fresh lacquer paint with 800 grit (P800) sand paper was considered hi-tech. Take a little corn starch, mix it with some water, put on your wool bonnet, and buff it to a shine...
Modern clear coats and rising expectations have continued to push the envelope in terms of paint correction procedures and products. The move towards finer and finer grades of polish and sand paper has allowed us, the crazy minded, swirl eliminating enthusiasts and professionals, to create gloss levels that simply could not be imagined in the days of cornstarch.
Autopia-CarCare.com is happy to announce the arrival of 3M's P5000 sanding discs. These discs are ultra fine, they only remove as much material as something with an equivalent 5000 "grit"; due to 3M's exclusive Trizact sanding surface, they leave an even finer finish!
The 3M Trizact P5000 (grit) Foam Discs are available in 3 sizes: 3 inch, 5 inch, and 6 inch.
3M Trizact 3 Inch 5000 Grit Foam Discs 30362
3M Trizact 5 Inch 5000 Grit Foam Discs 30562
3M Trizact 6 Inch 5000 Grit Foam Discs 30662
